1 - 20 of 383 Posts
'02 ETC CE, '04 CTS-V, '04 XLR, '13 XTS Platinum
2018 CT6E, old: 2014 XTS Vsport, 2005 CTS-V, 2004 CTS-V.
2014 RPO
Description
ACO
IDENTIFICATION – ACCESSORY CATALOG OFFERING
AEF
WINDOW – POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AER
WINDOW – POWER OPERATED, RR DRS, EXPRESS UP/DOWN
AE2
LATCH – REAR COMPARTMENT, SAFETY, MANUAL RELEASE
AFA
INTERIOR TRIM CONFIG – #1
AFB
INTERIOR TRIM CONFIG – #2
AFC
INTERIOR TRIM CONFIG – #3
AFD
INTERIOR TRIM CONFIG – #4
AFE
INTERIOR TRIM CONFIG – #5
AFF
INTERIOR TRIM CONFIG – #6
AFG
INTERIOR TRIM CONFIG – #7
AFH
INTERIOR TRIM CONFIG – #8
AG1
ADJUSTER FRONT SEAT – POWER, MULTI-DIRECTIONAL, DRIVER
AG2
ADJUSTER PASSENGER SEAT – POWER, MULTI-DIRECTIONAL
AHR
RESTRAINT – HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT
AKK
WINDOW STYLE – ACOUSTIC PVB
AKX
WINDSHIELD TYPE – SOLAR ABSORBING
AL0
SENSOR INDICATOR – INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
ANH
RESTRAINT SYSTEM – SEAT, INFLATABLE, DRIVER AND PASS FRT, FRT SEAT SIDE, FRT ROW ROOF SIDE, KNEE
APG
CONTROL – SEAT, POWER LUMBAR, LEFT
APH
CONTROL – SEAT, POWER LUMBAR, RIGHT
AP9
NET – CONVENIENCE
ASV
EQUIPMENT – SENSOR AIR MOISTURE & W/S TEMP
ATH
LOCK CONTROL, ENTRY – REMOTE ENTRY, EXTENDED RANGE, PASSIVE ENTRY, ALL DOORS
AXG
WINDOW – POWER OPERATED – EXPRESS DRIVER UP/DOWN
AXJ
VEHICLE TYPE – PASSENGER CAR
AYF
RESTRAINT SYSTEM – SEAT, INFLATABLE, DRIVER AND PASSENGER FRONT, FRONT SEAT SIDE AND REAR SEAT SIDE, ROOF SIDE, KNEE
A44
MEMORY – SEAT ADJUSTER, MIRROR, POWER, DRIVER/PASS, PERSONALIZATION
A51
SEAT – FRONT BUCKET, CUSTOM
A69
RESTRAINT – SEAT BELT TENSIONER, FRONT, VAR. 2
A70
A90
LOCK CONTROL REAR COMPARTMENT – LID, REMOTE CONTROL ELEC RELEASE
BTM
SWITCH – ENGINE START, KEYLESS
BTT
ALARM – REMOTE PANIC
BTV
REMOTE START – ENGINE
BV6
ORNAMENTATION – EXTR, RR COMPT LID "PLATINUM"
B05
BODY EQUIPMENT – ARMORED
B34
COVERING FRT – FLOOR MATS, CARPETED INSERT
B35
COVERING REAR – FLOOR MATS, CARPETED INSERT
B58
COVERING – FLOOR MAT, FRT AND RR, CARPETED INSERT
B85
MOLDING B/S – EXTERIOR, BRIGHT
B9Q
MODEL CONVERSION – HEARSE
CE1
WIPER SYSTEM – WINDSHIELD, PULSE, MOISTURE SENSITIVE
CJ2
HVAC SYSTEM – AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT
CJ4
HVAC SYSTEM – AIR CONDITIONING, FRT AND RR ELECTRONIC CONTROLS
C3U
ROOF – SUN, GLASS, SLIDING, ELEC, TRANSPARENT GLASS FIXED
C59
VENT – AIR, CONSOLE, RR
DA2
ARM REST – RR SEAT, STORAGE, PASS THROUGH
DBU
CONSOLE – FRT COMPT, FLOOR, ARM REST SLIDING
DB3
SUNSHADE – RR WINDOW, ELECTRIC
DCP
PROCESSING – DIRECTIONS AND CONNECTIONS SERVICE PACKAGE
DD8
MIRROR INSIDE REARVIEW – LIGHT SENSITIVE
DE8
SUNSHADE – WINDOW, RR SIDE
DH6
MIRROR INSIDE FRONT VANITY – LEFT AND RIGHT, SUNSHADE, ILLUM
DT4
ASHTRAY – CIGARETTE LIGHTER
DWK
MIRROR O/S – LH AND RH, RC, ELEC, HEAT, FLAT/DRVR, MANFOLD, CNVX/PASS, TURN SIG IND
DWL
MIRROR O/S – LH AND RH, RC, ELEC, HEAT, FLAT/DRVR, MANFOLD, CNVX/PASS, TURN SIG IND, LT SENS
D70
RATIO – TRANSAXLE FINAL DRIVE 2.77
EA1
POCKET – FRONT SEAT BACK, LEFT
EA2
POCKET – FRONT SEAT BACK, RIGHT
EAL
TRIM SEAT – LEATHER, SOLEIL KEISEL, MINI PERF
EF7
COUNTRY – UNITED STATES OF AMERICA (USA)
ESL
TRIM SEAT – LEATHER, OPUS MINI PERF
FE9
CERTIFICATION – EMISSION, FEDERAL
FHO
VEHICLE FUEL – GASOLINE E10
FKV
TRIM DOOR – PVC, CORINTHIAN MINI PERF
FKW
TRIM DOOR – LEATHER, PROVENCE
FKZ
TRIM DOOR – PUR, SHEFFIELD
FLA
TRIM DOOR – PUR, SHEFFIELD, VAR 1
FLB
TRIM DOOR – PVC, CORINTHIAN MINI PERF, VAR 1
FX3
RIDE AND HANDLING – AUTOMATIC ELECTRONIC CONTROLLED
F38
CHASSIS – REAR, AIR, INCREASED RIDE
F46
CHASSIS – ALL WHEEL DRIVE (AWD)
F55
CHASSIS – CONTINUOUSLY VARIABLE REAL TIME DAMPING MAGNETO RHEOLOGICAL
GAN
PRIMARY COLOR – EXTERIOR, SWITCHBLADE SILVER MET (G) 636R
GAZ
PRIMARY COLOR – EXTERIOR, SUMMIT WHITE (G) 8624
GBA
PRIMARY COLOR – EXTERIOR, BLACK (G) 8555
GBE
PRIMARY COLOR – EXTERIOR, CRYSTAL CLARET TINTCOAT (G) 505Q
GBN
PRIMARY COLOR – EXTERIOR, WHITE DIAMOND TRICOAT (G) 800J
GGC
GRILLE – CUSTOM
GKP
PRIMARY COLOR – EXTERIOR, MARY KAY PEARL TRI-COAT V (590Q)
GLJ
PRIMARY COLOR – EXTERIOR, ASHEN GRAY METALLIC 810T
GLK
PRIMARY COLOR – EXTERIOR, BLACK DIAMOND TRICOAT 815T
GNA
CHASSIS EQUIPMENT FRONT – STRUT ASM
GNB
CHASSIS EQUIP FRONT – STRUT ASM, PERFORMANCE
GNE
CHASSIS EQUIP REAR – REAR AXLE, H-ARM
GWT
PRIMARY COLOR – EXTERIOR, CHAMPAGNE SILVER MET (102V)
GW5
RATIO – TRANSAXLE FINAL DRIVE 3.16
GXH
PRIMARY COLOR – BERLIN BLUE MET (122V)
G96
AXLE POSITRACTION – LIMITED SLIP, ELECTRONIC
HD7
HANDLE – O/S, DR, ILLUMINATED
IO5
RADIO – INFOTAINMENT SYSTEM – UPLEVEL WITH CONNECTIVITY
IO6
RADIO – INFOTAINMENT SYSTEM – UPLEVEL WITH CONNECTIVITY AND EMBEDDED NAVIGATION
I14
ENGINEERING YEAR – 2014
J55
BRAKE SYSTEM – HEAVY DUTY
J6C
CALIPER COLOR – SILVER
J64
BRAKE SYSTEM – POWER, FRT AND RR DISC, ABS, 18+
J71
BRAKE PARKING – POWER OPERATED
KA1
HEATER SEAT FRT – DRVR AND PASS
KA6
HEATER SEAT – REAR
KB7
CONTROL – MANUAL SHIFT, AUTOMATIC TRANSMISSION
KD4
RECEPTACLE – ELECTRICAL, FRONT CONSOLE
KEH
KNOB – TRANS CONT LEVER, UPLEVEL
KI6
RECEPTACLE – ELECTRICAL, FRT CONSOLE RR 110 VOLT
KPA
KRV
REFRIGERANT – LOW GWP
KSG
CRUISE CONTROL – AUTOMATIC, ADAPTIVE, WITH STOP/GO
KTI
KIT, TIRE – INFLATOR
KU1
VENTILATED SEAT DRVR – FRONT
KU3
VENTILATED SEAT PASS – FRONT
KW5
GENERATOR – 220 AMP
KW7
GENERATOR – 170 AMP
K05
HEATER ENG – BLOCK
K34
CRUISE CONTROL – AUTOMATIC, ELECTRONIC
K4T
BATTERY – LN3, FLA, 12V, 80AH, 660 SAE
LFX
ENGINE – GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, E85 MAX, ALUM, GM
LF3
ENGINE – GAS, 6 CYL, 3.6L, SIDI, DOHC, VVT, ALUM, TWIN TURBO, GM
LHD
VEHICLE DRIVE – LEFTHAND DRIVE
MHM
TRANSMISSION – AUTO 6 SPD, HMD, 6T80, AWD, GEN 2
MWN
TAILPIPE – DUAL, INTEGRATED IN FASCIA
M7U
TRANSMISSION – AUTO 6 SPD, 6T70, AWD, GEN 2
M7V
TRANSMISSION – AUTO 6 SPD, 6T75, FWD, GEN 2
M7W
TRANSMISSION – AUTO 6 SPD, 6T70, FWD, GEN 2
NCG
LOCK – ELECTRICAL CHILD LOCK SYSTEM (REAR DOOR LATCH)
NE1
CERTIFICATION – EMISSION, GEOGRAPHICALLY RESTRICTED REGISTRATION FOR VEHICLES UP TO 14,000 LBS GVW (USE 2003 MDL YR)
NJ2
STEERING – ELECTRIC, BELT DRIVE
NKC
NOISE CONTROL – SYSTEM, ACTIVE NOISE CANCELLATION
NKD
NOISE CONTROL – ENGINE SOUND ENHANCEMENT
NR5
STEERING WHEEL – LEATHER, 4 SPOKES, DELUXE
NR7
STEERING WHEEL – LEATHER WRAPPED, HEATED (DO NOT USE AFTER 2012 M.Y.)
NT7
EMISSION SYSTEM – FEDERAL, TIER 2
NU5
EMISSION SYSTEM – CALIFORNIA, BIN 4
NU6
EMISSION SYSTEM – CALIFORNIA, PZEV
NWT
TAILPIPE – DUAL, TURNED DOWN. HIDDEN
NXC
STEERING – POWER, VARIABLE EFFORT, REDUCED RACK TRAVEL
N38
STEERING COLUMN – TILT, TELESCOPING, POWER
OSH
PLANT CODE – OSHAWA 1, ONT, CANADA
PMA
CONTROL – SEAT, MANUAL CUSHION EXTN, LH
PMB
CONTROL – SEAT, MANUAL CUSHION EXTN, RH
Q2B
TIRE ALL – P245/45R19 SL 98V BW AL3
Q6M
WHEEL – 19 X 8.5, J, ALUMINUM, DESIGN 2
RAL
TIRE ALL – P245/40R20 SL 95V BW AL3
RGS
TIRE ALL – 235/55R18 XL 104H BW ALS
RQ9
WHEEL – 20 X 8.5, J, ALUMINUM, DESIGN 1
RQA
WHEEL – 20 X 8.5, J, ALUMINUM, DESIGN 2
RT9
WHEEL – 19 X 8.5, J, ALUMINUM, DESIGN 1
RVN
WHEEL SPARE – 18 X 4.0, T, ALUMINUM, DESIGN 1
RV1
WHEEL – 18 X 8.0, J, ALUMINUM, DESIGN 3
RWS
ACCESSORY – FLOOR MATS – CARPET
RWU
ACCESSORY – CARGO AREA ORGANIZER – COLLAPSIBLE
SAO
ACCESSORY – SMOKERS PACKAGE
SFE
ACCESSORY – WHEEL LOCKS
S08
ACCESSORY – HIGHWAY SAFETY KIT
S2J
WHEEL SPARE – 18 X 8.0, J, ALUMINUM, DESIGN 3
S40
ACCESSORY – LINER – TRUNK/CARGO AREA
TG5
PLAYER – COMPACT DISC AND MP3
TL1
GRILLE – SPECIAL
TQ5
HEADLAMP HIGH BEAM – AUTO CONTROL
TR7
CONTROL, HEADLAMPS – LEVELING SYSTEM, AUTOMATIC
TSP
LAMP PACKAGE – INTERIOR, CUSTOM
TS6
LAMP – STOP, HIGH LEVEL
TU2
LAMP – MARKER, SIDE
T4F
HEADLAMPS – HIGH INTENSITY DISCHARGE
T61
LAMP SYSTEM – DAYTIME RUNNING
T83
HEADLAMPS CONTROL – AUTOMATIC ON-OFF
T95
CONTROL, HEADLAMPS – BEAM, DIRECTIONAL (AFL)
UDD
DISPLAY INSTRUMENT – DRIVER INFO ENHANCED (MULTI COLOR GRAPHIC)
UDT
INFOTAINMENT DISPLAY – COLOR INFO DISPLAY (CID) 8", WVGA, TOUCH SCREEN
UDV
DISPLAY INSTRUMENT – DRIVER INFO ENHANCED, FULL CLUSTER (MULTI COLOR GRAPHIC)
UD5
PARK ASSIST – FRONT AND REAR
UD7
SENSOR INDICATOR – REAR PARKING ASSIST
UEC
SENSOR INDICATOR – AUTOMATIC AIR RECIRCULATION
UEU
SENSOR INDICATOR – FORWARD COLLISION ALERT
UE1
COMMUNICATION SYSTEM – VEHICLE, GPS 1
UFG
SENSOR INDICATOR – REAR CROSS TRAFFIC ALERT
UFL
SENSOR INDICATOR – LANE DEPARTURE WARNING
UFQ
PARK ASSIST – FRONT, REAR, LATERAL-FRONT (SEMIAUTOMATIC STEERING ADVANCED PARKING AID)
UFT
SENSOR INDICATOR – SIDE OBSTACLE DETECTION
UG1
OPENER — GARAGE DOOR, UNIVERSAL
UGN
SENSOR – COLLISION AVOIDANCE AND MITIGATION, VEHICLE FORWARD MOVEMENT, BRAKE PREFILL AND INTELLIGENT BRAKE ASSIST
UH1
INDICATOR – SEAT BELT WARNING, RH
UJM
TIRE PRESSURE INDICATOR – MANUAL LEARN
UMN
SPEEDOMETER – INST, MILES & KILO, MILES ODOMETER
UQA
SPEAKER SYSTEM – PREMIUM AUDIO BRANDED WITH AMPLIFIER
UQG
SPEAKER SYSTEM – ENHANCED AUDIO WITH AMPLIFIER
UQS
SPEAKER SYSTEM – PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER
USR
RECEPTACLE – USB
US3
ANTENNA – DIVERSITY
UTJ
THEFT DETERRENT – ELECTRICAL, UNAUTHORIZED ENTRY
UVC
CAMERA – REAR VIEW
UVD
HEATER – STEERING WHEEL
UVZ
SENSOR – COLLISION AVOIDANCE AND MITIGATION, VEHICLE REVERSE MOVEMENT
UV6
DISPLAY – HEAD UP
UWG
ENTERTAINMENT PKG – RR SEAT, DUAL DISPLAY, REM CONTROL, AUX JACK, 2 WIRELESS DUAL CHANNEL HEADPHONES
U19
SPEEDOMETER – INST, KILO & MILES, KILO ODOMETER
U2M
DIGITAL AUDIO SYSTEM – S-BAND AND HD
U80
DISPLAY – COMPASS
VAV
ACCESSORY – FLOOR MATS – ALL WEATHER
VK3
LICENSE PLATE FRONT – FRT MOUNTING PKG
VLI
ACCESSORY – MAT – TRUNK/CARGO AREA
VUV
ACCESSORY – BRAKE PADS – PERFORMANCE
VXT
VEHICLE TYPE – INCOMPLETE
VYW
ACCESSORY – FLOOR MATS – PREMIUM CARPET – DESIGN 1
VZE
VIN MODEL YEAR – 2014
VZ3
LABEL – MERCURY DISPOSAL NOTIFICATION
V33
TOOL KIT – ROAD, EMERGENCY
V4U
MODEL CONVERSION – LIMOUSINE
V8D
VEHICLE STATEMENT – US
V8E
VEHICLE STATEMENT – CANADA
W1Y
CONTROL – STEERING WHEEL, RADIO, REDUNDANT CONTROLS
W2D
ACCESSORY – CARGO NET
W20
MERCHANDISED PKG – CADILLAC DEVILLE LIVERY
W28
CONTROL – REAR ARMREST, RADIO, REDUNDANT CONTROLS
W30
EQUIPMENT – STRETCH LIVERY
W68
CONTROL – REAR ARMREST, RR/BKLT S/SHADE, REDUNDANT CONTROLS
XFE
FUEL ECONOMY – EXTRA FUEL ECONOMY
XL7
FREQUENCIES RATING – 433 MHZ
XZ1
EQUIPMENT – PACKAGE, HOT WEATHER
YF5
CERTIFICATION – EMISSION, CALIFORNIA
YM8
IDENTIFICATION – LIMITED PERSONALIZATION OPTION (LPO)
ZB2
TIRE SPARE – 235/55R18 XL 104H BW ALS
ZCD
TIRE SPARE – T135/70R18 SL 104M BW SPR
Z49
COUNTRY – CANADA
01A
TRIM COLOR SEAT – JET BLACK VAR 1
01F
TRIM COLOR SEAT – SHALE
01S
TRIM COLOR SEAT – MED TITANIUM
05B
TRIM COLOR SEAT – CARAMEL TAN
05C
TRIM COLOR SEAT – V LT PLATINUM
1AB
TRIM COLOR DR PANEL – JET BLACK
1AR
TRIM COLOR DR PANEL – MED TITANIUM
1BE
TRIM COLOR DR PANEL – COCOA
1CQ
TRIM COLOR DR PANEL – CARAMEL TAN
1CR
TRIM COLOR DR PANEL – V LT PLATINUM
1CS
TRIM COLOR DR PANEL – LT WHEAT
1SA
PACKAGE – OPTION 01
1SB
PACKAGE – OPTION 02
1SC
PACKAGE – OPTION 03
1SD
PACKAGE – OPTION 04
4AA
INTERIOR TRIM – JET BLACK
4AV
INTERIOR TRIM – JET BLACK/MED TITANIUM
4B8
INTERIOR TRIM – COCOA/SHALE
4CW
INTERIOR TRIM – JET BLACK/CARAMEL TAN
4CY
INTERIOR TRIM – DK URBAN/COCOA/V LT PLATINUM
4CZ
INTERIOR TRIM – JET BLACK/LT WHEAT
5A7
WHEEL SPARE – NONE
9H8
LAMP SYSTEM – DAYTIME RUNNING, AUXILIARY
9L3
TIRE SPARE – NONE
2014 XTS Platinum VSport AWD
Thanks for posting all of the 2014 RPO Codes. Now if I can only find the RPO label on my XTS. I've looked everywhere in the trunk that I can without tearing it totally apart and I still haven't found it. Maybe I should just ask the dealer the next time I take it in to provide me with a copy of the RPO label?
2016 XTS Premium Radiant Silver
Hello! I just bought a beautiful black on black 2013 Cadillac XTS4 Premium and would like to verify the standard and options features the car has. Can you please provide me with the original build sheet/information for my car? Thank you in advance for your time!
VIN 2G61T5S32D9177762
Sincerely,
Bill
Depending on the replies you get, a call to the salesman (if you bought at a GM dealer) can quickly result in an email with all the info you need. While the Build Sheet is great - The Service History is even more important.
For anyone reading who might be contemplating buying any pre-owned Cadillac, ALWAYS review the Service History to determine the car's status before spending a penny. It might shed light as to why it's on the lot, and offer peace of mind if it's been trouble-free.
If you didn't buy from a GM dealer, you can drop by one and have them print both out when supplied with the VIN.
CC
2016 XTS FWD Platinum
Sincerely,
Bill
Here you go. Hope it helps!
Max
01A - TRIM COLOR SEAT JET BLACK
1AB - TRIM COLOR DR PANEL JET BLACK
1SC - PREMIUM COLLECTION
1SZ - DISCOUNT OPTION PACKAGE
4AA - INTERIOR TRIM JET BLACK
6FD - COMPONENT FRT LH COMPUTER SEL SUSP (6FD)
7FD - COMPONENT FRT RH COMPUTER SEL SUSP (7FD
8FK - COMPONENT RR LH COMPUTER SEL SUSP (8FK)
9FK - COMPONENT RR RH COMPUTER SEL SUSP (9FK)
9H8 - DAYIME RUNNING LAMPS AUXILIARY
A45 - MEMORY SETTINGS, DRIVER SEAT, OUTSIDE MIRRORS, POWER RAKE & TELESCOPIC STEERING COLUMN
A51 - FRONT BUCKET SEATS
A69 - RESTRAINT SEAT BELT TENSIONER, FRT, VAR. 2
A70 - RESTRAINT SEAT BELT TENSIONER, FRT
A90 - LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE
AE2 - LATCH RR COMPARTMENT, SAFETY, MANUAL RELEASE
AEF - WINDOW POWER OPERATED, PASSENGER, EXPRESS UP/DOWN
AER - WINDOW POWER OPERATED, RR DRS EXPRESS UP/DOWN
AFC - JET BLACK
AG1 - ADJUSTER FRT ST POWER, MULTI-DIRECTIONAL, DRIVER
AG2 - ADJUSTER PASS ST
AHR - RESTRAINT HEAD, FRT SEAT, UP/DOWN, FORE/AFT ADJUSTMENT
AKK - WINDSHIELD STYLE ACOUSTIC PVB
AKX - WINDSHIELD TYPE SOLAR ABSORBING
AL0 - AIRBAG SENSING SYSTEM, PASSENGER
AP9 - CONVENIENCE NET, TRUNK
APG - PWR SEAT ADJUSTER, DRIVER, 4-WAY LUMBAR
APH - PWR SEAT ADJUST, FRONT PASS 4 WAY LUMBAR
ATH - EZ KEY PASSIVE ENTRY SYSTEM
AXG - WINDOW POWER OPERATED-EXPRESS DRIVER UP/DOWN
AXJ - VEHICLE TYPE PASSENGER CAR
AYF - AIRBAGS, DRIVER & PASSENGER FRONTAL & SIDE IMPACT HEAD SIDE CURTAIN
B34 - FLOOR ÉMATS, FRONT
B35 - FLOOR MATS, REAR
B85 - BODY SIDE MOLDING, BODY COLOR
BTM - KEYLESS START
BTT - PANIC ALARM BUTTON
BTV - ADAPTIVE REMOTE START
C3U - ULTRAVIEW SUNROOF SKYLIGHT
C59 - VENT AIR, CONSOLE, RR
CE1 - WINDSHIELD WIPERS, RAIN SENSING
CJ4 - CLIMATE CONTROL, TRI ZONE
D70 - RATIO TRANSAXLE FINAL DRIVE 2.77
DA2 - ARM REST RR SEAT, STORAGE, PASS THROUGH
DBU - CONSOLE, FRT COMPARTMENT FLOOR, ARM REST SLIDING
DD8 - INSIDE REARVIEW MIRROR, AUTO DIMMING
DH6 - MIRROR I/S FRT VAN LH & RH, SUNSHADE, ILLUM
DWL - POWER DUAL OUTSIDE MIRRORS ADJUSTABLE, W/AUTO DIMMING & TURN SIGNAL INDICATOR
EA1 - POCKET FRONT SEAT BACK, LH
EA2 - POCKET FRONT SEAT BACK, RH
EAL - SEAT TRIM, SOLEIL KEISEL MINI PERFORATED INSERTS, LEATHER SEATING SURFACES
EF7 - COUNTRY CODE - UNITED STATES OF AMERICA (USA)
EPM - MODEL CONVERSION ALL WHEEL AWD F38 - AUTOMATIC LEVEL CONTROL REAR AIR SUSPENSION
F46 - CHASSIS, ALL WHEEL DRIVE
F55 - MAGNETIC RIDE CONTROL
FE9 - 50-STATE EMISSIONS
FHO - VEHICLE FUEL GASOLINE E10
FLB - TRIM DOOR PVC, CORINTHIAN MINI PERF, VAR 1
FX3 - STABILITRAK-STABILITY CONTROL SYSTEM W/ TRACTION CONTROL
G96 - DIFFERENTIAL, ELECTRONIC LIMITED SLIP
GBA - BLACK RAVEN
GNB - SUSPENSION FRONT PERFORMANCE
GNE - SUSPENSION, REAR H ARM
HD7 - DOOR HANDLES, ILLUMINATED
I13 - ENGINEERING MODEL YEAR
IO6 - NAVIGATION SYSTEM AM/FM STEREO, EMBEDDED VOICE RECOGNITION
J64 - BRAKES, ANTILOCK 4 WHEEL DISC BREMBO
J71 - BRAKE, PARKING
K34 - CRUISE CONTROL
K4T - BATTERY LN3, FLA, 12V, 80AH, 660 SAE
KA1 - DRIVER & FRONT PASSENGER HEATED SEATS
KA6 - SEATS, HEATED REAR OUTBOARD POSITIONS
KB7 - CONTROL MANUAL SHIFT, AUTOMATIC TRANSMISSION
KD4 - RECEPTACLE ELECTRICAL, FRT CONSOLE
KEH - SHIFT LEVER, LEATHER-WRAPPED WITH WOOD
KI6 - POWER OUTLET, 120 VOLT
KPA - RECEPTACLE ELECTRICAL, FRT CONSOLE RR
KRV - REFRIGERANT LOW GWP
KU1 - SEAT, VENTILATED DRIVER
KU3 - SEAT, VENTILATED PASSENGER
KW7 - GENERATOR
LFX - ENGINE, 3.6L SIDI DOHC V6 VVT
LHD - VEHICLE DRIVE LEFTHAND DRIVE
M7U - TRANSMISSION, 6-SPEED AUTOMATIC AWD
MAH - MARKETING AREA US, PR, USVI
MM1 - MERCHANDISED TRANS AUTO EQUIPMENT
MWN - EXHAUST, DUAL-OUTLET STAINLESS STEEL
N38 - STEERING COLUMN, POWERTILT & TELESCOPIC
NCG - LOCK ELECTRICAL CHILD LOCK SYSTEM (REAR DOOR LATCH)
NKC - NOISE CONTROL SYSTEM, ACTIVE NOISE CANCELLATION
NR7 - STEERING WHEEL, LEATHER WRAP HEATED W/ TAP UP/DOWN CONTROL
NT7 - EMISSION - FEDERAL
NXC - POWER STEERING, VARIABLE EFFORT RACK AND PINION
OSH - PLANT CODE OSHAWA
PCW - DRIVER AWARENESS PACKAGE
PMA - SEAT ADJUSTER, DRIVER, THIGH ADJUST
PMB - SEAT ADJUSTER, FRONT PASSENGER, THIGH ADJUST
Q2B - TIRES, ALL SEASON BLACKWALL
R7D - IDENTIFIER - I PAD
R9N - CONTROL SALES ITEM NO. 89
RT9 - WHEELS, 19" POLISHED ALUMINUM
RVN - WHEEL, 18" ALUMINUM SPARE
SLM - STOCK ORDERS
T4F - HEADLAMPS, HIGH INTENSITY DISCHARGE, WINDSHIELD WIPER ACTIVATED, FLASH TO PASS FEATURE
T83 - HEADLAMPS CONTROL AUTOMATIC ON/OFF
T95 - HEADLAMPS, ADAPTIVE FORWARD LIGHTING
TG5 - AUDIO SYSTEM FEATURE, CD/MP3 PLAYER, GLOVE BOX MOUNTED
TR7 - NAME HEADLAMPS CONTROL LEVELING SYSTEM, AUTOMATIC
TS6 - LAMP STOP, HIGH LEVEL
TSP - LIGHTING
TU2 - LAMP MARKER, SIDE
U2M - SIRIUSXM AND HD RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY SIRIUSXM AFTER 3 MONTHS
U80 - DISPLAY COMPASS
UD5 - FRONT AND REAR PARKINGASSIST ULTRASONIC
UDT - INFOTAINMENT DISPLAY COLOR INFO DISPLAY (CID) 8", WVGA
UDV - GAUGE CLUSTER WITH COLOR DRIVER INFORMATION CENTER
UE1 - 1 YR ONSTAR DIRECTIONS AND CONNECTIONS WITH AUTOMATIC CRASH RESPONSE & TURN-BY-TURN NAVIGATION (ASK DEALER ABOUT GEOGRAPHIC COVERAGE)
UEC - SENSOR, AUTOMATIC AIR CIRCULATION
UEU - FORWARD COLLISION ALERT
UFG - REAR CROSS TRAFFIC ALERT NOTIFICATION
UFL - LANE DEPARTURE WARNING
UFT - SIDE BLIND ZONE ALERT
UG1 - OPENER GARAGE DOOR, UNIVERSAL
UH1 - INDICATOR SEAT BELT WARNING, RH
UJM - TIRE PRESSURE MONITOR SYSTEM (EXCL SPARE TIRE)
UMN - SPEEDOMETER INST, MILES & KILO, MILES ODOMETER
UQS - AUDIO SYSTEM, BOSE SURROUND SOUND, 14 SPEAKERS
US3 - ANTENNA DIVERSITY
USR - RECEPTACLE USB
UTJ - CONTENT THEFT ALARM, THEFT DETERRENT SYSTEM
UV6 - HEAD-UP DISPLAY
UVC - REAR VISION CAMERA SYSTEM
UVD - HEATED STEERING WHEEL
V33 - TOOL KIT
V8D - VEHICLE STATEMENT US
VK3 - FRONT LICENSE PLATE BRACKET
VRG - VAA/COMPONENT REL COCKPIT
VRH - VAA/COMPONENT REL STEERING COLUMN
VRK - VAA/COMPONENT REL ROOF TRIM
VRL - VAA/COMPONENT REL FRONT HORIZONTAL SUSPENSION
VRM - VAA/COMPONENT REL FRONT VERTICAL SUSPENSION
VRN - VAA/COMPONENT REL REAR SUSPENSION
VRR - VAA/COMPONENT REL TIRES & WHEELS
VZD - MODEL YEAR IDENTIFIER
W1Y - CONTROL STEERING WHEEL, RADIO, REDUNDANT CONTROLS
WGA - COLLECTION RDO EQUIP RECEIVING UNIT, RADIO
XFE - FUEL ECONOMY EXTRA FUEL ECONOMY
XL7 - FREQUENCIES RATING 315 MHZ, LONG DISTANCE
ZCD - TIRE, COMPACT SPARE
Thank you! I never thought of something as simple as that. I agree, the Service History is very important information to have when making a car buying decision. I will do that in the future.
Thank you!
Thank you, Max! I really appreciate it.
2015 XTS
Maximln that is excellent.
Can you show me the build sheet for my 2015 XTS Luxury, I find it very helpful. Sometimes this sheet is in the tire area but mine did nipot have one.
VIN 2G61M5S3XF9245581
Best regards,
Len
No problem! Glad I could help!
Max
Thank you!
Best regards,
Len
Sure Len! No problem! Here you go!
Max
01F - RIM COLOR SEAT SHALE
1BE - TRIM COLOR DR PANEL COCOA
1SB - LUXURY COLLECTION
4B8 - INTERIOR TRIM COCOA / SHALE
5A7 - SPARE WHEEL, NOT DESIRED
6CT - COMPONENT FRT LH COMPUTER SEL SUSP (6CT)
7CT - COMPONENT FRT RH COMPUTER SEL SUSP (7CT)
9H8 - AUX. DAYTIME RUNNING LAMPS
9L3 - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE
A44 - MEMORY PACKAGE - DRIVER /FRT PASS. SEATS, OUTSIDE MIRRORS, TELESCOPIC STEERING COLUMN * POWER DUAL OUTSIDE MIRRORS ADJUSTABLE, W/AUTO DIMMING & TURN SIGNAL INDICATOR
AFD - SHALE W/ COCOA ACCENTS
AXJ - VEHICLE TYPE - PASSENGER CAR
BTM - KEYLESS START
BZ4 - GM PRODUCTION WEEK
CJ2 - AIR CONDITIONING, DUAL ZONE CLIMATE CONTROL
D70 - AXLE, 2.77 FINAL DRIVE RATIO
DA2 - ARMREST, REAR PASS THRU
DNV - EA1 - POCKET FRONT SEAT BACK, LH
EF7 - COUNTRY CODE, U.S.A.
F55 - MAGNETIC RIDE CONTROL WITH REAR AIR SPRINGS
FLA - TRIM DOOR PUR, SHEFFIELD, VAR 1
FLT - FLEET PROCESSING OPTION
GWT - SILVER COAST METALLIC
I15 - ENGINEERING YEAR 2015
K4T - BATTERY, RUNDOWN PROTECTION,
KTI - TIRE SEALANT & INFLATOR KIT IN PLACE OF SPARE TIRE
KW7 - GENERATOR
M7W - TRANSMISSION, 6-SPEED AUTOMATIC FWD
MAH - MARKETING AREA NORTH AMERICA
NJ2 - STEERING, POWER, VARIABLE ASSIST, ELECTRIC
NT7 - EMISSION SYSTEM FEDERAL
PCW - DRIVER AWARENESS PACKAGE * FORWARD COLLISION ALERT * REAR CROSS TRAFFIC ALERT * LANE DEPARTURE WARNING * LANE KEEP ASSIST * SIDE BLIND ZONE ALERT
PED - VOMS TRACKING CODE
R6F - B-CODE ASSIGNMENT VOMS
R9N - CONTROL SALES ITEM NO. 89 REH - 19" PAINTED ALLOY WHEELS
TSP - LIGHTING
U2M - SIRIUSXM AND HD RADIO + SERVICE SUBSCRIPTION SOLD SEPARATELY SEPARATELY BY SIRIUSXM AFTER 3 MONTHS
UDD - DISPLAY, MULTI-COLOR DRIVER INSTRUMENT INFO ENHANCED
UE1 - 1 YR ONSTAR DIRECTIONS AND CONNECTIONS W/ AUTOMATIC CRASH RESPONSE & TURN-BY-TURN NAV PLUS 5-YEAR ONSTAR BASIC PLAN (OMITS SAFETY, SECURITY & NAV) (SEE ONSTAR.COM)
UFQ - AUTOMATIC PARKING ASSIST
UG1 - UNIVERSAL HOME REMOTE
UHX - LANE KEEP ASSIST
UQA - AUDIO SYSTEM- PREMIUM
VAV - FLOOR MATS, ALL WEATHER FRONT AND REAR (DEALER INSTALLED)
VV4 - ONSTAR(R) 4G LTE WI-FI(R) HOTSPOT W/ 3GB/3MO DATA TRIAL
WMF - VIN MODEL YEAR 2015
XFE - FUEL ECONOMY EXTRA FUEL ECONOMY X
YM8 - IDENTIFICATION LIMITED PERSONALIZATION OPTION (LPO)
2015 XTS
Your the best. Maximln, I used to be a great contributor to the Jaguar forums for many years, and now have purchased a XTS Cadillac a couple of months ago. Will see how it goes. So far the car is great; however dealers service far from adequate here in Wisconsin.
Glad I could help! That's too bad. Most Cadillac dealerships are very good but it's like anything. There are some good ones out there & there are also some bad ones! I've driven Cadillacs my entire life. I couldn't imagine driving anything else but they have always been V8's. Once they got rid of the Northstar, I thought they would come out with something else but hopefully they will soon!
Max
1 - 20 of 383 Posts
