1 - 20 of 21 Posts
The Northstar Tuner
Systematic Approach
Diagnostic Information and Procedures
Tire and Wheel Inspection
Road Test
Types of Road Test
Classifying the Vibration
Vibrations That Can Be Felt
Vibrations That Make Noise
Matching Frequency to Component RPM
Rotor/Drum Imbalance
Front Wheel Driveline Vibrations
Engine Related Vibration
Tire and Wheel Vibration
The Northstar Tuner
Discussion Starter #2
Systematic Approach
During the last 10-15 years, vehicle design and engineering have dramatically changed due to the following factors:
Increased fuel costs
Decreased fuel supplies
Corporate Average Fuel Economy requirements
Clean air legislation
Foreign competition
Ability to withstand collision
Rising customer expectations
Most Vehicle designs have evolved from full-frame construction to lighter unibody designs. These designs transfer noise and vibration much more readily.
During this same period, options such as the following have become increasingly popular:
Air conditioning
Power steering
All-wheel or four wheel drive
Such options increase engine load and can also generate unwanted noise and vibration.
Customer perception of quality can be directly linked to the presence or absence of unwanted noise and vibration. A technician's ability to quickly diagnose and repair a noise or vibration directly affects that customer's loyalty to the dealership.
The intent of this sub-section of the service manual is to provide a systematic approach to vehicle vibration diagnosis and correction. By using Strategy Based Diagnosis and troubleshooting philosophies covered in this sub-section, technicians will be able to provide effective and timely repairs.
The Northstar Tuner
This section describes the techniques and procedures for correcting the following types of vibrations:
Tire and wheel shake
Launch shudder
Exhaust moan
Engine firing frequency
Drive line vibration
Identifying the Concern
The first step in diagnosing a vibration concern is to identify the exact vibration that concerns the customer.
Sometimes the vibration can be duplicated at a given speed. Other vibrations may not be as evident and may require questioning the customer carefully. Perform a road test with the customer in the vehicle in order to determine the specific vibration complaint.
Ask the following questions when attempting to identify a vibration complaint:
At what speed is the vibration the worst?
Can the customer feel the vibration? If so, where?
Can the customer hear the vibration?
Does the engine or the vehicle load affect the vibration?
Does the vibration occur in more than one gear range?
When did the vibration first appear?
The answers to these questions will help in duplicating and diagnosing the vibration.
If you suspect that the vibration is normal, compare the vibration with a vehicle that is equipped in the same way, including the following factors:
Body style
Engine option
Engine driven accessories
Transmission type
Tire size
Suspension performance type
Axle ratio
Important
Do NOT attempt to repair a normal condition, or the customer will probably be convinced that the vehicle has a problem. Customer satisfaction becomes extremely difficult after this point.
If necessary, ride with the customer. Make the comparison with the customer present and explain the situation.
Duplicate the Condition
All vehicles produce vibrations. Some vibrations are normal, while others are not. Some vibrations can be repaired, some cannot. Duplicate or experience the customer's complaint. Evaluate the vibration and the cause of the vibration under changing conditions. Otherwise, you cannot know for certain that you are fixing what the customer would like fixed.
The symptoms and characteristics of a noise or vibration are also important information. Ask yourself the following questions before you begin:
What does the vibration feel like?
Does the vibration make noise? If so, what does the vibration sound like?
Different types of noise and vibration have particular characteristics. These characteristics will help determine the cause of the condition and the best way to correct the condition.
A Process of Elimination
You must understand a few basic concepts before attempting to diagnose a vibration. As in any diagnostic process, you must perform the following steps:
Gather the information
Decipher the information
Make your correction based on the results
Road test the vehicle and inspect the vehicle in a manner which systematically eliminates different components. This process supplements the information which you have received from the customer concerning the complaint. Concentrating efforts on the areas that have not been eliminated will make repairs faster and more effective.
The Northstar Tuner
The tires on all new production models have a tire performance criteria (TPC) rating number molded on the sidewall. The TPC rating will appear as a 4-digit number preceded by the letters TPC SPEC on the tire wall near the tire size. A replacement tire should have the same TPC rating.
FIGURE Tire Wear(c)
(1) Hard Cornering/Underinflation
(2) Incorrect Alignment/Lack of Rotation
(3) Incorrect Alignment/Non-uniform Tire
(4) Heavy Acceleration/Over inflation
(5) Wear Indicator
Inspect the tire and wheel assemblies for the following conditions:
Unusual wear such as cupping, flat spots, and heel-and-toe wear. (These conditions can cause tire growl, howl, slapping noises, and vibrations throughout the vehicle.)
Proper inflation
Bulges in the sidewalls (Do not confuse bulges with normal ply splices, commonly seen as indentations in the sidewall.)
Bent rim flanges
By inspecting these characteristics of the tire and wheel assemblies, you may discover the cause of the vibration. The inspection will also provide assurance that the vehicle is safe for road testing.
The Northstar Tuner
Road Test
Purpose of Road Testing
Important
The purpose of road testing is to duplicate the vibration complaint and to find any operating conditions that change or eliminate the vibration. Most importantly, road testing will determine whether the vibration is related to the engine speed or to the vehicle speed.
In order to complete a quick and accurate road test, install an engine tachometer (such as a scan tool) and the Electronic Vibration Analyzer (EVA) in the vehicle. Place the EVA vibration sensor in a location where the customer's concern can be felt.
Determining the Component Group
After you have related a vibration to either the engine speed or to the vehicle speed, break the vibration down further in order to fit into one of the following groups of rotating components:
The engine, the clutch disc (manual transmission), the transmission flywheel (automatic transmission), and the transmission torque converter.
The transmission output shaft, the propeller shaft, and the rear axle differential pinion.
The tires, the wheels, the hubs, the drums, and the rotors.
These three groups represent the major areas that can produce vibration complaints. The components in each group are related to each other because the components are either bolted or splined together. This means that each group of components rotates at the exact same speed.
These categories can be broken down further in order to identify the exact component responsible for the disturbance. The emphasis is on testing in order to pinpoint the source and to eliminate unnecessary parts replacement.
Perform a road test for ALL vibration complaints unless the disturbance occurs only with the vehicle at a standstill.
The Northstar Tuner
Types of Road Test
Caution: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage.
Important: Before performing any road test, inspect the tires and wheels. Refer to Tire and Wheel Inspection .
The following road test procedures are the most informative and the most used:
• Slow acceleration test
• Neutral coast-down test
• Downshift test
• Neutral run-up test
• Brake torque test
• Steering input test
• Standing start acceleration test (launch shudder)
These tests will help to pinpoint the vibration. Perform all of the tests on a smooth, level road.
Slow Acceleration Test
This test will identify those conditions which are related to the engine-speed or to the vehicle-speed. Additional tests may be necessary in order to determine the exact cause of the vibration.
On a smooth, level road, slowly accelerate up to highway speed.
Look for disturbances that match the customer's description.
Observe the following readings where the disturbance occurs:
• The vehicle speed, km/h (mph)
• The engine speed (RPM)
• The frequency (if possible)
Now perform the neutral coast-down test and the downshift test.
Neutral Coast-Down Test
On a smooth level road, accelerate to a speed slightly higher than the speed at which the vibration occurs.
Shift the vehicle into NEUTRAL gear and coast down through the vibration range.
Observe whether the vibration is present in NEUTRAL gear.
If the vibration still occurs in NEUTRAL gear, then the vibration is definitely sensitive to vehicle-speed. At this point, the following components have been eliminated as a cause of the vibration:
• The engine
• The clutch disc (manual transmission)
• The transmission flywheel (automatic transmission)
• The torque converter
Depending on the symptoms or the frequency, the repair will concentrate on one of the following components:
• The tire and wheel assemblies
• The transmission output shaft
• The propeller shaft
• The rear axle differential pinion
• The rear drive axle or the rear drive axle shafts
Downshift Test
On a smooth, level road, accelerate to the speed at which the concern vibration occurs.
Observe the engine RPM.
Decelerate and safely downshift to the next lower gear.
Operate the vehicle at the previous engine RPM.
If the vibration returns at the same engine RPM, the following conditions are the most probable causes of the vibration:
• The engine
Repeat this test in lower gears, and in NEUTRAL gear, in order to confirm the results.
In some cases, a vibration may also be sensitive to torque or engine load, as well as being related to a specific engine speed or vehicle speed. These vibrations can be most difficult to diagnose, and require additional testing. A systematic approach usually leads to isolating the problem.
Neutral Run-Up Test
This test is designed to identify vibrations which are related to the speed of the engine. Use this test when the customer has a concern with vibration at idle, or as a follow-up to the downshift test. This test probably doesn't apply when the complaint is related to vehicle speed only (appearing at the same vehicle speed regardless of the engine speed).
Slowly increase the engine speed while looking for disturbances that match the customer's complaint.
Observe the engine speed (RPM) and the frequency (if possible) where the vibration occurs.
Brake Torque Test
This test is designed to identify engine-related vibrations that were not uncovered with the neutral run-up test. This test also works for vibrations that are sensitive to the engine load or to the torque. This test will probably not apply to vibrations which are related only to the speed of the vehicle.
  1. Apply the park brake.
  2. Block the front wheels.
  3. Step firmly on the brake pedal.
  4. Place the vehicle in DRIVE.
  5. Slowly increase the engine speed while looking for vibrations that match the customer's description.
  6. Observe the engine speed (RPM) and the frequency (if possible) at which the disturbance occurs.
  7. If necessary, place the vehicle in REVERSE gear and repeat steps 5 and 6.
Steering Input Test
This test is intended to determine how much the wheel bearings and other suspension components contribute to the vibration, especially a vibration relating to noise, such as growl, grinding, and roaring.
  1. With the vehicle at the vibration speed (mph), drive through slow sweeping turns, first in one direction and then in the other direction.
  2. If the vibration gets worse or if the vibration goes away, inspect the following components as possible causes of the vibration:
• The wheel bearings
• The hubs
• The tire tread
The CV joint angle increases when the vehicle is turning. On front weel drive (FWD) and four wheel drive (4WD) vehicles, CV joint condition systems may appear when the angle increases. Putting a load on the CV joint may increase the vibration amplitude. The third order, tire speed related amplitude would remain the same.
Standing Start Acceleration (Launch Shudder) Test
The purpose of this test is to duplicate a vibration called launch shudder. In some cases, a powertrain mount or an exhaust ground-out may also be the cause of the vibration, depending on the symptoms.
  1. With the vehicle at a complete stop and in gear, remove your foot from the brake pedal.
  2. Accelerate to 48-64 km/h (30-40 mph) while looking for vibrations that match the customer's description.
  3. Other possible causes of launch shudder include the following conditions:
• Incorrect trim height.
• A worn or damaged drive axle CV joint
• A ground-out through the engine or transmission mounts
• Faulty exhaust hangers and mounts
The Northstar Tuner
The next step after road testing the vehicle is to identify the frequency of the duplicated and abnormal vibration. Use the EVA in order to measure the frequency. If the EVA is not available, observe how the vibration feels or sounds. The majority of vibrations will fit into one of the following categories.
• Vibrations that can be felt:
- Shake
- Roughness
- Buzz
- Tingling
• Vibrations that make noise:
- Boom
- Moan and groan
- Howl
- Whine
The Northstar Tuner
Discussion Starter #8
Shake
Shake is a low frequency vibration, typically 5-25 Hz. Shake is sometimes felt in the steering wheel, the seat, or the console. The best description is the feeling from an out-of-round or unbalanced tire. Customers may refer to a shake in one of the following terms:
Shimmy
Wobble
Shudder
Waddle
Hop
In most cases, shake is caused by damage or wear to the following components:
The tires
The wheels
The brake rotors (vehicle-speed sensitive)
The steering tie rod ends
The suspension ball joints
The engine (engine-speed sensitive)
Roughness
Roughness is a vibration with a slightly higher frequency than the shake, usually 25-50 Hz. Roughness is similar to the feeling you get from holding a jigsaw.
Buzz
Buzz is slightly higher in frequency, usually 50-100 Hz. A buzz is similar to the feel of an electric razor. You may feel it in your hands through the steering wheel, in your feet through the floor, or in the seat. Inspect the following components for a possible cause:
The exhaust system
The A/C compressor
The engine
Tingling
This is the highest vibration frequency that you can feel. Tingling may sometimes produce a pins and needles sensation. Customers may say the vibration creates numbness in their hands or feet.
The Northstar Tuner
Discussion Starter #9
Boom
Boom is a low frequency interior noise of 20-60 Hz. Sometimes the customers complain of a pressure in their ears. Examples of similar noises include a bowling ball rolling down an alley, deep thunder, or a bass drum.
A customer may use the following words to describe boom:
Droning
Growling
Moaning
Roaring
Rumbling
Humming
Boom may be accompanied by a perceptible vibration (roughness).
Moan or Groan
Moan or Groan is a sustained tone at a low frequency of 60-120 Hz, somewhat higher than boom.
Examples of similar noises include a bumble bee or blowing air across the top of a soda bottle. A customer may use the following words to describe moan or drone:
Humming
Buzzing
Resonance
Moan or Groan may be accompanied by a perceptible buzzing vibration. Inspect the following systems:
The powertrain mounts
The exhaust system
Howl
Howl is a noise at mid-range frequency of 120-300 Hz. This sounds like the wind howling.
Whine
Whine is a prolonged, high-pitched sound in the 300-500 Hz range. Whine is usually related to the meshing gears or gear noise. Similar sounds include mosquitoes, turbine engines, and vacuum cleaners.
The Northstar Tuner
Discussion Starter #10
At this point in the diagnosis, the vibration has gone through the following analysis:
• The vibration has been duplicated.
• The vibration has been designated as abnormal.
• The vibration has been related either to engine speed or to vehicle speed.
• The vibration has been assigned a frequency from the Smart Electronic Vibration Analyzer (Smart EVA) or identified based on its feel or its sound.
Automotive vibrations are usually related to the rotating speed of a component. Calculate the speed of these components using either an engine speed method or a vehicle speed method. Use the engine RPM readings taken during the road test in order to diagnose the vibrations that are sensitive to engine speed.
If the vibration is sensitive to vehicle speed, determine the rotational speed of the tires. As long as you operate the vehicle at a constant speed, the tires will operate at a constant speed. This speed is measured in rotations, or cycles per second. The reading is then compared to the frequency of the vibration, which is also measured in cycles per second.
Calculating Tire Rotation
The Smart EVA program is designed to perform targeted frequency calculations on a suspected vibration source. The tire size, axle ratio, number of cylinders, vehicle speed and engine rpm are factored into a calculation that determines the predominant vibration frequency, amplitude and the suspected vehicle system producing the vibration.
  1. Use the Smart EVA to determine the speed at which the vibration occurs.
  2. From the main menu, select Auto Mode, then click enter; select Vehicle Speed, then click enter.
  3. Enter the vehicle tire size information with one of three options:
  4. - RPS at 5 mph -- Refer to the Tire/Speed table below for the Hertz value at 8 km/h (5 mph) for that tire size.
  5. - Database -- Select the tire type and tire size from each selection screen. Tip: when browsing the tire size or axle ratio list, press a number key to go to a related point in the list; for example, press 1 to go to the top of the list; press 4 or 5 to go to the middle of the list; press 9 to go to the bottom of the list.
  6. - Manual Entry -- Select Manual Entry when the vehicle is fitted with speciality tires. Enter the tire width (100-500 mm), aspect ratio (0.30-1.50) and rim diameter (10.00-25.00 in).
  7. Enter the driveshaft configuration.
  8. Enter the axle ratio, refer to the Axle Ratio table below,(2.00-9.00) from the Axle Ratio selection screen. Note: Axle Ratio is not applicable if front wheel drive (FWD) is selected.
  9. Select the vehicle speed units in miles-per-hour (MPH) or Kilometers-per-hour (KPH).
  10. Enter the vehicle speed at which the vibration is felt.
  11. As the test is run, the vehicle speed must be manually adjusted to match the actual vehicle speed:
  12. - Select the incremental step you want to increase/decrease vehicle speed, then click enter.
  13. - View the frequency ranges applicable for the speed selected, press enter to go to the active data screen or exit to go back and reselect the speed if you are not within a valid range.
  14. - Click the up or the down key to adjust the on-screen vehicle speed on the live data screen to match the actual vehicle speed.
  15. Data is displayed as averaged (A is displayed) or instantaneous (I is displayed). Press key 8 to toggle. The amplitudes of the vibrations detected are displayed in descending order beginning with line 2. Repair the strongest vibration first. One to three sources of vibration are identified:
  16. - TIRE 1,2,3 or 4 (1st, 2nd, 3rd or 4th order tire/wheel system concern).
  17. - PROP 1 or 2 (Propshaft concern).
  18. - OVERLAP (overlap of Tire 3 and Prop 1 frequencies).
  19. - UNKNOWN (vibration source is unknown).
  20. Data is received through input A (A is displayed) or B (B is displayed). Press key 4 to toggle.
  21. The vehicle speed (V) is displayed in mph or kph. Press the down or up key to manually adjust this figure to match actual vehicle speed.
  22. An identification letter symbol displays during record (R) or playback (P).
  23. During record or playback the event and frame numbers are displayed. If an event is not selected, a "?" appears. During record or playback the frame number cycles from 0 to 9; for example, 0:0, 0:1, 0:2...0:9.
  24. Amplitude of the signal is displayed in number of G forces (G).
Steering and Suspension Assembly Vibrations
Steering and suspension assembly vibrations are the first level of testing for low-frequency vibrations that are sensitive to vehicle speed. The symptoms of a steering/suspension first-order vibration are a shimmy or a shake. This is usually felt in the steering wheel or in the seat. Inspect the following components for wear or damage:
• The steering tie rod ends.
• The suspension ball joints.
• The tires.
• The wheels.
• The brake rotors (vehicle-speed sensitive).
• The engine (engine-speed sensitive).
The Northstar Tuner
Discussion Starter #11
Rotors and drums do not have a set tolerance. However, rotors or drums with more than 21 g (0.75 ounce) imbalance have the potential to cause vibration. Inspect the rotors and the drums for imbalance using either the on-vehicle or the off-vehicle method.
Checking Rotor/Drum Imbalance (On-Vehicle)
Support the vehicle rear axle on a suitable hoist. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the rear tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Caution: One or more of the following guidelines may apply when performing specific required tests in the work stall:
• When a test requires spinning the drive wheels with the vehicle jacked up, adhere to the following precautions:
- Do not exceed 56 km/h (35 mph) when spinning one drive wheel with the other drive wheel stopped. This limit is necessary because the speedometer indicates only one-half the actual vehicle speed under these conditions. Personal injury may result from excessive wheel spinning.
- If all of the drive wheels are spinning at the same speed, do not exceed 112 km/h (70 mph). Personal injury may result from excessive wheel spinning.
- All persons should stay clear of the rotating components and the balance weight areas in order to avoid possible personal injury.
- When running an engine in the repair stall for an extended period of time, use care not to overheat the engine and the transmission.
• When a test requires jacking up the vehicle and running with the wheels and brake rotors removed, adhere to the following precautions:
- Support the suspension at normal ride height.
- Do not apply the brake with the brake rotors removed.
- Do not place the transmission in PARK with the drive axles spinning.
- Turn Off the ignition in order to stop the powertrain components from spinning.
• When running an engine in the work stall, use the exhaust removal system to prevent breathing dangerous gases.
Reinstall the wheel nuts in order to retain the rotors/drums.
Run the vehicle at the complaint speed while inspecting for the vibration.
If the vibration still exists, perform the following steps:
Remove the rotors/drums.
Run the vehicle back to speed.
If the vibration is eliminated, perform the following steps:
Remove the rotors/drums one at a time.
Perform the vibration test for each rotor/drum.
Replace the rotor/drum that is causing the imbalance.
Inspect the balance of the new rotor/drum.
Checking Rotor/Drum Imbalance (Off-Vehicle)
Measure the diameter and the width of the rotor/drum.
Mount the rotor/drum on a balancer in the same manner as a wheel.
Important: You can only inspect the rotors/drums for static imbalance. Ignore the dynamic imbalance reading.
Inspect for static imbalance.
If the rotor/drum shows imbalance, replace the rotor/drum.
Inspect the balance of the new rotor/drum before you install the rotor/drum on the vehicle.
The Northstar Tuner
Discussion Starter #12
Front wheel drive shafts have the following characteristics
• The front wheel drive shafts are short.
• The front wheel drive shafts have constant-velocity (CV) universal joints.
• The front wheel drive shafts have low mass.
• The front wheel drive shafts turn or spin at a lower rate of speed than the propeller shaft on a RWD vehicle.
Although FWD is smoother than RWD, the following problem conditions may occur and require diagnosis and correction:
• Launch shudder
• Third-order tire-related vibrations
• Growling (wheel bearing) noise
• Clicking noise or shudder during turns
Launch Shudder
Launch shudder is a shaking sensation that is felt in the steering wheel and/or the front of the vehicle during moderate to heavy acceleration from a standing start. Launch shudder may also be a rocking back-and-forth motion in the vehicle during acceleration.
On front-wheel-drive vehicles, launch shudder can be caused by the following conditions:
• Worn or damaged inner tri-pot joints
• Excessive inner joint angularity
Excessive joint angles are usually the result of a front trim or a spring height that is set too high. A powertrain mounting that is damaged or misaligned can also create the following conditions:
• Excessive joint angles
• Launch shudder
During fast acceleration, the front suspension height is raised by the high torque of the vehicle powertrain. When the suspension height rises, the inner tri-pod joint angles increase and can cause a launch shudder condition if one of the following conditions are present:
• The joints are worn.
• The angles are already excessive before acceleration.
Because the inner tri-pot joint is usually the cause of launch shudder, the disturbance is typically related to third-order tire rotation frequency.
Identify the type of disturbance.
Visually inspect the drive axles for worn or damaged inner joints.
If you detect no obvious problem, measure the trim or spring height in order to determine if the suspension is causing an excessive joint angle. Do not measure the body height. Body height measurements are not used because potential sheet metal variations could lead to mis-diagnosis of the problem cause. Trim height specifications are found in the vehicle service manual.
If the spring height is out-of-specification, place sandbags under the following locations in order to lower the suspension:
- Under the hood
- Over the strut towers
Road test the vehicle, adding sandbags until you eliminate the disturbance.
In order to lower the suspension, measure the spring height in order to determine the required springs to install.
Each vehicle line has multiple spring options with different spring rates. You can achieve approximately 10 mm of suspension height change by dropping down one spring code. You can locate the spring codes in the following areas:
• On the springs
• On the SPID label in the vehicle
Important: Always replace the springs in matching sets in order to insure correct body levels and proper suspension performance.
You can find the list of available springs in the parts catalog.
Third-Order Tire-Related Vibrations
Tri-pot joints are so named because of their design characteristics. Tri-pot or tri-potal joints have three trunnions (or a trilobal spider assembly) that fit into a race or a cup. The assembly moves in and out freely in order to compensate for drive axle length changes during suspension travel.
Although worn or damaged inner tri-pot joints can cause launch shudder, worn or damaged inner tri-pot joints may also cause vehicle speed-related, third-order tire vibrations.
Third-order tire-related disturbances can occur if the following conditions are present:
• The joint becomes worn or damaged.
• The joint has excessive free-play or lash.
The worn joint creates three disturbances per revolution of the axle shaft. Because the axle shaft turns at the same rate as the wheel, third-order tire-related vibrations will result.
Growling (Wheel Bearing) Noise
Front-wheel-drive (FWD) hub and bearing assemblies can make a low, growling noise that increases with the vehicle speed. The tires and the bearings can make a similar noise. The tires and bearings are vehicle-speed-sensitive.
In order to differentiate between tire noise and bearing noise, drive the vehicle in a straight line and perform several turning maneuvers side-to-side. A worn wheel bearing typically exhibits increased noise during turns. If the noise level increases during a right-hand turn, then the left-hand wheel bearing generally is causing the problem. The opposite is true for a left-hand turn. If a bearing and not the tires is the cause of the disturbance, the noise level increases when turning because an added load is applied to the bearing with the fault.
Clicking Noise or Shudder During Turns
A clicking noise or a shudder during vehicle turns is usually a symptom caused by one of the following conditions:
• A worn or damaged outer constant-velocity (CV) joint
• A worn or damaged outboard CV joint
During a visual inspection of the drive axle, look for a damaged boot on the outer CV joint. A damaged boot can allow water and other contaminants such as dust and dirt to compromise lubrication and prematurely destroy the joint. The CV joint will no longer function smoothly, causing the disturbance.
The Northstar Tuner
Discussion Starter #13
Engine vibration is usually due to one or more of the following conditions:
• First-order engine imbalance
• Inherent engine firing sequence
• Inherent shaking engine forces
• Engine-driven accessories
Because these vibrations are engine-speed related, they are also normally torque sensitive. These vibrations may appear and disappear at different vehicle or road speeds, but will always appear at the same engine speed.
For example, if a customer states that a vibration is present at 40 km/h (25 mph), 64 km/h (40 mph), and again at 104 km/h (65 mph), and that the symptoms of the vibration are similar at all of these speeds, the vibration is probably engine-speed related. Any disturbance or vibration that is present during the following road tests would be considered engine-speed related:
• The Neutral run-up test
• The downshift test
• The brake torque test
Any vibration that is present during the Neutral coast-down test is not engine-speed related. The engine-related vibrations covered in this diagnosis are engine-speed sensitive only.
Skipped the rest
The Northstar Tuner
Discussion Starter #14
Tire and wheel assembly vibrations are the next level of testing for low-frequency vibrations that are sensitive to vehicle speed. The tires, the wheels, the brake rotors, and the wheel hubs should be systematically tested, according to the symptoms.
First-Order Tire and Wheel Assembly Vibration
The following are symptoms of first-order vibrations caused by tire and wheel assemblies:
• The vibration is always related to the speed of the vehicle. If the vibration is affected by the speed of the engine, or if the vibration is eliminated by placing the transmission in Neutral, the vibration is not related to the tire and wheel assemblies.
• The vibration will feel like a shake, usually in the steering wheel or the seat.
- Tire and wheel vibrations that are felt in the steering wheel are most likely related to the front tire and wheel assemblies.
- Tire and wheel vibrations that are felt in the seat or the floor are most likely related to the rear tire and wheel assemblies. This may not always hold true, but this is a general rule that may serve to initially isolate a problem to the front or the rear of the vehicle.
• The customer may complain of a waddle at low speeds of 8-56 km/h (5-35 mph).
• The frequency on the EVA will correspond to the first-order of tire rotation. This frequency will usually be in the 10-20 Hz range, depending on the speed of the complaint and the size of the tire. The smaller the tire, the faster the tire will rotate at any given speed.
• The range of the human ear begins at 20 Hz. For this reason, first-order tire vibrations rarely produce noise. The exception is when the tires display an irregular tread pattern or flat spots. This causes a growling or a slapping noise.
Tire Runout Measurement
Correct the runout problem first, because the runout of a tire/wheel assembly will directly affect the amount of imbalance and radial force variation. As the amount of runout decreases, imbalance and force variation also decrease.
Important: Before measuring or attempting to correct excessive runout, carefully inspect the tire for an uneven bead seat. The distance from the edge of the ring to the concentric rim locating ring should be equal around the entire circumference. If the beads are not seated properly, remount the tire. Otherwise excessive runout and imbalance may result.
You can correct radial and lateral runout at the same time. Two methods are available for measuring runout of the tire/wheel assemblies:
• On the vehicle (mount the tire to the hub; the wheel bearing must be in good condition.)
• Off the vehicle (mount the tire on a spin-type tire balancer)
Make an initial on-car visual inspection prior to performing the off-car runout tests.
Measuring the tire/wheel runout off the vehicle is the easier method for the following reasons:
• A dial indicator can be more easily mounted in the correct location.
• The chance of water, snow, dirt, or slush getting on the dial indicator is decreased. (A dial indicator is a very fragile and expensive tool that is used extensively in vibration repair work. Contamination by outside elements or rough handling will usually result in malfunction).
Once you have measured and corrected the runout off the vehicle, a quick examination of runout on the vehicle will indicate if any further problems exist.
If the off-vehicle measurement differs significantly from the on-vehicle measurement, the runout problem is due to one of the following:
• Stud circle runout
• Hub flange runout
• A mounting problem between the wheel and the vehicle.
Measuring Tire Runout
If a vehicle sits in one place for an extended period of time, flat spots may develop at the point where the tires rest upon the ground. These flat spots will affect the runout readings. Before you take any runout measurements, eliminate these flat spots by driving the vehicle long enough to warm up the tires.
  1. Lift the vehicle on a hoist or support the vehicle with jackstands. Refer to Lifting and Jacking the Vehicle in General Information.
  2. In order to get an initial indication of how much runout exists, spin each tire and wheel on the vehicle by hand. You may also use the engine at a slow speed in order to drive the wheels. Visually inspect the amount of runout from the front or the rear.
  3. Mark the location of each tire/wheel assembly in relation to the wheel studs and to their position on the vehicle for future reference.
  4. Remove the tire/wheel assemblies one at a time. Mount each assembly on a spin-type wheel balancer. Locate the tire/wheel assembly on the balancer with a cone through the back side of the center pilot hole.
  5. For lateral runout place the dial indicator in a smooth area on the tire sidewall as close to the tread as possible.
FIGURE Lateral Tire Runout(c)
FIGURE Radial Tire Runout(c)
Measure the tire/wheel assembly runout as shown in the figure.
For radial runout, wrap the outer circumference with tape (1) when you measure the radial runout. This allows for a smooth reading from the dial indicator.
Ignore any jumps or dips due to sidewall splices.
Use either of the following dial indicator sets with roller contact point. Special Tools and Equipment
• J 8001 with a clamp-on base
• J 7872 with a magnetic base
Load the indicator and slowly rotate the assembly one complete revolution.
Set the indicator to zero on the low spot.
Rotate the assembly one more complete revolution and note the total amount of runout indicated. The maximum allowable assembly radial and lateral runout is 0.050 inch when measured off the vehicle and 0.060 inch when measured on the vehicle.
Vectoring (Match Mounting)
If the runout is excessive, mark the location of the high spot (3) and the low spot on the tire. Next, determine if the runout problem exists in the tire, the wheel, or a combination of both. Then, correct the problem. This procedure, called match-mounting or vectoring, uses the following steps:
Important: After replacing a tire or a wheel, remeasure the tire/wheel assembly runout in order to verify that the runout is within tolerance.
  1. Place a mark (2) on the tire sidewall at the location of the valve stem (5). This mark is the 12 o'clock position. Always refer to the location of the high spot (3) in relation to its clock position on the wheel.
  2. Mount the tire/wheel assembly on a tire machine and break down the bead. Do not dismount the tire from the wheel at this time.
  3. Rotate the tire 180 degrees on the rim so that the valve stem reference mark (8) is now at the 6 o'clock position in relation to the valve stem (6) itself. You may need to lubricate the bead in order to easily rotate the tire on the wheel.
  4. Reinflate the tire and seat the bead properly.
  5. Mount the assembly on the tire balancer and remeasure the runout. Mark the new location of the runout high point on the tire.
  6. If runout is now within tolerance, no further steps are necessary. Balance and mount the tire on the vehicle. Refer to Balancing Tires and Wheels .
• If the clock location of the high spot remained at or near the clock location of the original high spot (7), the wheel is the major contributor to the runout problem. Refer to Wheel Runout Measurement.
If the high spot (7) is now at or near a position 180 degrees from the original high spot, the tire is the major contributor to the runout problem. Replace the tire.
• If the high spot is in between the two extremes, then both the tire and the wheel are contributing to the runout. Rotate the tire an additional 90 degrees in both the clockwise and the counterclockwise directions.
FIGURE Lateral Wheel Runout(c)
FIGURE Radial Wheel Runout(c)
Complete the following steps if you cannot bring runout within tolerance by match-mounting:
  1. Dismount the tire from the wheel.
  2. Measure the radial wheel runout and the lateral wheel runout
FIGURE Radial Wheel Runout (Tire Removed)(c)
FIGURE Lateral Wheel Runout (Tire Removed)(c)
You can measure rim runout more accurately on the inside bead area of the wheel. Measure wheel runout using the same procedure as tire runout. Ignore any jumps or dips due to paint drips, chips, or welds.
Measure both the inboard flange and outboard flange as shown. The tolerances for wheel runout are as follows:
• Steel Wheels:
- Radial runout--0.040 in
- Lateral runout--0.045 in
• Aluminum Wheels:
- Radial runout--0.030 in
- Lateral runout--0.030 in
If the runout of the wheel is beyond the tolerance, replace the wheel.
Important: Always measure the runout of new wheels. Do not assume that a new wheel is automatically good.
When replacing a steel wheel, refer to the wheel code that is stamped next to the valve stem. When replacing an aluminum wheel the code is stamped on the back side of the wheel, cross-reference the letter code with the parts book.
If the runout of the wheel is within tolerance, and the tire/wheel assembly runout cannot be reduced to an acceptable level by using the match-mounting technique, replace the tire.
Important: Always remeasure the tire/wheel assembly runout after you replace the tire.
If you notice a large difference in runout measurements between on-vehicle testing and off-vehicle testing, the runout problem is due to one of the following:
• Hub flange runout
The listed tolerances should serve only as a guideline. If runout measurements are within tolerance but are marginal, some sensitive vehicles may still be affected. Always reduce runout to as little as possible in order to attain optimum results under all conditions.
Radial Force Variation
Radial force variation is the difference in the stiffness of a tire (1) as the tire rotates and contacts the road. The tire and wheel assemblies have some variation due to splices in the tire plies. These splices do not cause a problem unless the force variation is excessive. These stiff spots in the tire can deflect the tire and wheel assembly upward as the assembly contacts the road.
If the tire has only one stiff spot, the spot will deflect the spindle once per each revolution of the tire and wheel assembly, thus causing a first-order tire/wheel vibration. If the tire has two stiff spots, the spots cause a second-order vibration. First-order and second-order tire/wheel vibrations are the most common as a result of radial force variation. Third-order, fourth-order, or higher are possible but rarely occur.
Ensure that the tire and wheel assembly runout is at an absolute minimum. This is the most effective way to minimize the possibility of force variation as a factor in tire and wheel assembly vibrations. However, some tire and wheel assemblies exhibit vibration-causing force variation even though they are within runout and balance tolerances. These instances are becoming increasingly rare due to tighter tolerances and higher standards in manufacturing.
If you suspect force variation as a factor in tire and wheel assembly vibration complaints, substitute one or more known good tire and wheel assemblies.
You may buff the tires on a tire matching machine in order to eliminate spindle deflection. This type of equipment, not currently in widespread use, is designed to remove small amounts of rubber from the outer rows of the tread blocks at the location of the stiff spots under load. Do not use any tool that is designed to make the tire perfectly round. These tools will not correct the condition.
You may substitute one or more known good tire and wheel assemblies when a tire manufacturer is not available locally.
Lateral Force Variation
Lateral force variation tends to deflect the vehicle to the side, or laterally. Lateral force variation is based on the same concept as radial force variation. A snaky belt inside the tire may be the cause of lateral force. Test the vehicle with substitute tires before installing replacement tires.
A lateral force variation condition is rare. The best way to eliminate lateral force variation is to ensure that the lateral runout of the tire and wheel assemblies is at an absolute minimum.
The vehicle will wobble or waddle at slow speeds of 8-40 km/h (5-25 mph) when lateral force variation is excessive. This condition is usually related to the first-order of tire and wheel rotation.
Wheel Hub/Axle Flange Runout
When lateral runout occurs, inspect the wheel hub/axle flange runout if you are performing an on-vehicle test procedure, but not during off-vehicle testing. The tolerances provided are only guidelines. Perform corrections only if the on-vehicle runout cannot be brought to within tolerance.
  1. Position the dial indicator on the machined surface of the hub, the axle flange, or the rotor outside of the wheel studs.
  2. Rotate the hub in order to find the low spot.
  3. Set the dial indicator to zero at the low spot.
  4. Rotate the hub again and check the total amount of runout.
Specification (Guideline)
Runout tolerance: 0.13 mm (0.005 in)
Wheel Stud (Stud Circle) Runout
Use the wheel stud runout procedure whenever the following conditions occur:
• The off-vehicle radial runout differs significantly from the on-vehicle radial runout
• Earlier attempts to correct the tire and wheel vibration condition have been unsuccessful
  1. Position the dial indicator in order to contact the wheel mounting studs. Measure the stud runout as close to the flange as possible.
  2. Turn the hub to register on each of the studs.
  3. Zero the dial indicator on the lowest stud.
Runout tolerance: 0.25 mm (.010 in)
The Northstar Tuner
Discussion Starter #15
The Northstar Tuner
Discussion Starter #16
I will post more in the morning
:D
The Northstar Tuner
Discussion Starter #17
Basic Terms
Important
DO NOT attempt to repair a normal condition, or the customer will probably be convinced that the vehicle has a problem. Customer satisfaction becomes extremely difficult after this point.
The following are the 2 primary components of vibration diagnosis:
The physical properties of objects
The object's properties of conducting mechanical energy
The repetitive up/down or back/forth movement of a component causes most customer vibration concerns. The following are the common components that vibrate:
The steering wheel
The seat cushion
The frame
The instrument panel
Vibration diagnosis involves the following steps:
  1. Measure the repetitive motion and assign a value to the measurement in cycles per second or cycles per minute.
  2. Relate the frequency to the rotational speed of a component that is operating at the same rate or speed.
  3. Inspect and test the components for conditions that cause vibration.
For example, performing the following steps will help demonstrate the vibration theory:
  1. Clamp a yardstick to the edge of a table, leaving approximately 50 cm (20 in) hanging over the edge of the table.
  2. Pull down on the edge of the stick and release while observing the movement of the stick.
The motion of the stick occurs in repetitive cycles. The cycle begins at midpoint, continues through the lowest extreme of travel, then back past the midpoint, through the upper extreme of travel, and back to the midpoint where the cycle begins again.
The cycle occurs over and over again at the same rate, or frequency. In this case, approximately 10 cycles per second. If we measure the frequency to reflect the number of complete cycles that the yardstick made in one minute, the measure would be 10 cycles x 60 seconds = 600 cycles per minute (cpm).
We have also found a specific amount of motion, or amplitude, in the total travel of the yardstick from the very top to the very bottom. Redo the experiment as follows:
  1. Clamp the yardstick to the edge of a table, leaving approximately 25 cm (10 in) hanging over the edge of the table.
The stick vibrates at a much faster frequency: 30 cycles per second (1,800 cycles per minute). The total travel, or amplitude, is less.
Vibration
Vibration is the repetitive motion of an object, back and forth, or up and down. The following conditions cause most vehicle vibrations:
A rotating component
The engine combustion process firing impulses
Rotating components will vibrate with excessive imbalance or runout. During vibration diagnosis, the amount of allowable imbalance or runout should be considered a tolerance and not a specification. In other words, the less imbalance or runout, the better.
A vibration concern will occur when the firing impulses of the engine are not properly isolated from the passenger compartment.
A vibrating component operates at a consistent rate (km/h, mph, or RPM). Measure the rate of vibration in question. When the rate/speed is determined, relate the vibration to a component that operates at an equal rate/speed in order to pinpoint the source. Vibrations also tend to transmit through the body structure to other components. Therefore, just because the seat vibrates does not mean the source of the vibration is in the seat.
Vibrations consist of the following three elements:
The source -- the cause of the vibration
The transfer path -- the path on which the vibration travels through the vehicle
The responder -- the component where the vibration is felt
In the preceding figure, the source of the vibration is the unbalanced tire. The transfer path is the route the vibrations travels through the vehicle's suspension system into the steering column. The responder is the steering wheel, which the customer reports as vibrating. Eliminating any one of these three elements will usually correct the condition. From the gathered information, decide which element makes the most sense to repair. Adding a brace to the steering column may keep the steering wheel from vibrating, but adding a brace is not a practical solution. The most direct and effective repair would be to properly balance the tire.
Vibration can also produce noise. As an example, consider a vehicle that has an exhaust pipe which is grounded to the frame. The source of the vibration is the engine firing impulses traveling through the exhaust. The transfer path is a grounded or bound-up exhaust hanger. The responder is the frame. The floor panel vibrates, acting as a large speaker, which produces noise. The best repair would be to align the exhaust system and correct the grounded condition at the frame. This would eliminate the transfer path.
Cycle
(1) 1st Cycle
(2) 2nd Cycle
(3) 3rd Cycle
(4) Time
FIGURE Vibration Cycles in Powertrain Components(c)
(1) Spindle
(2) Pinion Nose
The word cycle comes from the same root as the word circle: both begin and end at the same point. All vibrations consist of repetitive cycles.
Frequency
(1) Amplitude
(2) Reference
(3) Time in Seconds
(4) 1 Second
Frequency is defined as the rate at which an event occurs during a given period of time. With a vibration, the event is a cycle, and the period of time is one second. Thus, frequency is expressed in cycles per second, or Hertz (Hz). Multiply the Hertz by 60 to get the cycles, or revolutions per minute (RPM).
Amplitude
(1) Maximum
(2) Minimum
(3) Zero-to-Peak Amplitude
(4) Peak-to-Peak Amplitude
Amplitude is the maximum value of a periodically varying quantity. Used in vibration diagnostics, amplitude is the magnitude of the disturbance. A severe disturbance would have a high amplitude and a minor disturbance would have a low amplitude.
Amplitude is measured by the amount of actual movement, or the displacement. For example, consider the vibration caused by an out-of-balance wheel at 80 km/h (50 mph) as opposed to 40 km/h (25 mph). As the speed increases, the amplitude increases.
The Northstar Tuner
Discussion Starter #18
Basic Terms Continued
Free Vibration
Free vibration is the continued vibration in the absence of any outside force. In the yardstick example, the yardstick continued to vibrate even after the end was released.
Forced Vibration
Forced vibration is when an object is vibrating continuously as a result of an outside force.
Centrifugal Force Due to an Imbalance
(1) Location of Imbalance (Degrees)
(2) Centrifugal Force Acting on Spindle
A spinning object with an imbalance generates a centrifugal force. Performing the following steps will help to demonstrate centrifugal force:
  1. Tie a nut to a string.
  2. Hold the string. The nut hangs vertically due to gravity.
  3. Spin the string. The nut will spin in a circle.
Centrifugal force is trying to make the nut fly outward, causing the pull you feel on your hand. An unbalanced tire follows the same example. The nut represents the imbalance in the tire. The string represents the tire/wheel/suspension assembly. As the vehicle speed increases, you can feel the disturbing force of the unbalanced tire in the steering wheel, the seat, and the floor. This disturbance will be repetitive (Hz) and the amplitude will increase. At higher speeds, both the frequency and the amplitude will increase. As the tire revolves, the imbalance, or the centrifugal force, will alternately lift the tire up and force the tire downward, along with the spindle, once for each revolution of the tire.
Natural or Resonant Frequency
The natural frequency is the frequency at which an object tends to vibrate. Bells, guitar strings, and tuning forks are all examples of objects that tend to vibrate at specific frequencies when excited by an external force.
Suspension systems, and even engines within the mounts, have a tendency to vibrate at certain frequencies. This is why some vibration concerns occur only at specific vehicle speeds or engine RPM.
The stiffness and the natural frequency of a material have a relationship. Generally, the stiffer the material, the higher the natural frequency. The opposite is also true. The softer a material, the lower the natural frequency. Conversely, the greater the mass, the lower the frequency.
Resonance
(1) Frequency - cps
(2) Suspension Frequency
(3) Unbalanced Excitation
(4) Point of Resonance
(5) Problem Speed
All objects have natural frequencies. The natural frequency of a typical automotive front suspension is in the 10-15 Hz range. This natural frequency is the result of the suspension design. The suspension's natural frequency is the same at all vehicle speeds. As the tire speed increases along with the vehicle speed, the disturbance created by the tire increases in frequency. Eventually, the frequency of the unbalanced tire will intersect with the natural frequency of the suspension. This causes the suspension to vibrate. The intersecting point is called the resonance.
The amplitude of a vibration will be greatest at the point of resonance. While you may feel the vibration above and below the problem speed, you will feel the vibration the most at the point of resonance.
Damping
(1) Low Damping
(2) High Damping
Damping is the ability of an object or material to dissipate or absorb vibration. The automotive shock absorber is a good example. The function of the shock absorber is to absorb or dampen the oscillations of the suspension system.
Beating (Phasing)
Two separate disturbances that are relatively close together in frequency (1, 2) will lead to a condition called beating, or phasing when the disturbances are combined (3). Beating occurs when two vibrating forces are adding to, or subtracting from, each other's amplitude. A beating vibration condition will increase in intensity or amplitude in a repetitive fashion as the vehicle travels at a steady speed. This beating vibration can produce the familiar droning noise heard in some vehicles. In many cases, eliminating either one of the disturbances can correct the condition.
Order
Order refers to how many times an event occurs during one revolution of a rotating component.
For example, a tire with one high spot would create a disturbance once for every revolution of the tire. This is called first-order vibration.
An oval-shaped tire with two high spots would create a disturbance twice for every revolution. This is called second-order vibration. Three high spots would be third-order, and so forth. Two first-order vibrations may add or subtract from the overall amplitude of the disturbance, but that is all. Two first-order vibrations do not equal a second-order vibration. Due to centrifugal force, an unbalanced component will always create a first-order vibration, at minimum.
The Northstar Tuner
Discussion Starter #19
If you managed to understand this you will understand That ALL 96+ FWD Cadillac's will have a tire vibration at the same speed + - 4 MPH. This is because the 3.11 gears have smaller tires and the 3.71 have taller tires. The Cycle, Frequency, and Amplitude will reach its greatest at or about 62 MPH + - 4 mph.
The Northstar Tuner
Discussion Starter #20
NEW WORK SHEET
It helps to be able to answer some of the basic question when you go in to th dealer.
When diagnosing vibration concerns, use the following worksheet in conjunction with the appropriate Vibration Analysis-Road testing procedure in the Vibration Correction sub-section in SI. FILL OUT ONLY THE APPLICABLE PORTION OF THE WORKSHEET THAT APPLIES TO THE VIBRATION/NOISE.
Refer to the appropriate section of SI for specifications and repair procedures that are related to the vibration concern.
Vibration Analysis Worksheet
To:
Dealer:
Fax Number:
VIN__ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
Procedure Performed By:
Date:
Model:
Year: Gear Ratio:
Odometer:
VIN __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __
TAC Case #, if applicable:
Conditions During Road Test Procedures
As condition occurs: Engine RPM_____________
Vehicle Speed__________________
Vibration/Noise detected during the following road test procedures:
Engine RPM_______________ Vehicle Speed_______________
Slow Acceleration Test: Yes__________ No__________
Neutral Coast-Down Test: Yes__________ No__________
Downshift Test: Yes__________ No__________
Neutral Run-Up Test: Yes__________ No__________
Brake Torque Test: Yes__________ No__________
Steering Input Test: Yes__________ No__________
Standing Start Acceleration (Launch Shudder) Test: Yes__________ No__________
Vibration/Noise Eliminated with TCC Commanded On: Yes__________ No__________
Vibration/Noise Eliminated with TCC Commanded Off: Yes__________ No__________
Vibration/Noise Duplicated on Hoist: Yes__________ No__________
When using the EVA, always take a snapshot. This will help determine which vibration shows up the most.
Important: Vibrate software can also be used to assist in vibration diagnosis. Refer to Vibrate Software Description and Operation in SI.
EVA Readings
Refer to Electronic Vibration Analyzer (EVA) Description and Operation in SI for more detailed information.
Important: As a reminder, place the EVA sensor where the vibration is mostly felt. Ensure the word "UP" on the sensor is physically facing up. The typical areas are the seat track, the steering column or the instrument panel. Locating the EVA sensor on additional area (i.e. the right fender, left fender, right quarter panel, left quarter panel, rear seat track, etc.) may also assist in determining the component causing the vibration/noise. The key is to look for the same Hz reading with the greatest amplitude G readings.
FILL OUT ONLY THE APPLICABLE PORTION OF THE WORKSHEET THAT APPLIES TO THE VIBRATION/NOISE:
Sensor at Steering Column:
1st Line MPH/KPH:__________ HZ:__________ Gs:__________
2nd Line MPH/KPH:__________ HZ:__________ Gs:__________
Sensor at Roof:
Sensor at Passenger Seat Rail:
Sensor at Pinion Nose (Rear Wheel Drive):
Sensor at Pinion Nose Front Axle (Four Wheel Drive):
Sensor at Crossmember/Cradle (Front Wheel Drive):
Driveshaft Runout:
Is round out within specification? Yes__________ No__________
Initial: Frt:__________ Center:__________ Rear:__________ Stub Shaft:__________
Current: Frt:__________ Center:__________ Rear:__________ Stub Shaft:__________
Pinion Flange Runout Reading:__________
Has a system balance been attempted: Yes__________ No__________ (If no, perform a System Balance)
Were the drums removed to system balance? Yes__________ No__________
Initial: HZ__________ Gs__________
Current: HZ__________ Gs__________
Hose clamps added: Yes__________ No__________
Prop shaft indexed? Yes__________ No__________
If a System Balance has been attempted but the vibration is still present or system balance was not able to be achieved, check the ring gear backlash in eight different spots on the ring gear. Note that excessive ring gear runout may result in a first order tire speed or first order prop shaft speed concern.
Backlash in eight equal spots on the ring gear (readings should not vary more than 0.002 in (0.050 mm)):
1__________ 2__________ 3__________ 4__________ 5__________ 6__________ 7__________ 8__________
Does the vehicle have any of the following components attached?
Pinion damper: Yes__________ No__________
Pinion flange damper: Yes__________ No__________
Exhaust damper: Yes__________ No__________
Initial: Front angle:__________ Center Angle:__________ Rear Angle:__________
Current: Front angle:__________ Center Angle:__________ Rear Angle:__________
Were shims added to the following?
Transmission/transfer case mount: Yes__________ No__________
Pinion nose (rear springs): Yes__________ No__________
Center Support Mount: Yes__________ No__________
Tire Size and Brand:_____________________________________
Wheel/Tire Runouts on vehicle (max. 0.050 in (1.27 mm))
Refer to Corporate Bulletin Number 00-03-10-006A for tire radial force variation.
Right rear: Inner lateral:__________ Center radial:__________
Left rear: Inner lateral:__________ Center radial:__________
Right front: Inner lateral:__________ Center radial:__________
Left front: Inner lateral:__________ Center radial:__________
Mounting surface runouts (max. 0.005 in (0.127 mm))
Flange, right rear:__________ Hub, right front:__________
Flange, left rear:__________ Hub, left front:__________
Wheel stud runouts (max. 0.008 in (0.203 mm))
1 - 20 of 21 Posts
