2004 Cadillac CTS-V
So I've been reading up on the V1 to V2 brake swaps and I'm trying to get my car together for autocross and track days. The front brakes need to be done so it seems like a good time to do the swap, but I need to get some new tires and stuff as well so I'm trying to keep the cost somewhat reasonable. Is there a reasonably priced bolt on rotor that goes with the V2 calipers? I've seen the RB ones, but would prefer just a single piece rotor to get ready for some early season autocross events, I'll likely upgrade to 2-piece rotors later.
In the event that the RBs are the only bolt on option, where would I even go to get the center hub and lug holes drilled?
Thanks!
'05 CTS-V
Assuming you're sticking with your stock 6x115 hubs, there are no bolt-on 1-piece rotor options. With the RB rotors there would be no need to get anything drilled - you can get the V2 rotor rings on V1 hats.
Any machine shop should be able to drill the bolt pattern and enlarge the hub bore.
2007 cts v
You can use any stock size rotor with a v2 caliper upgrade
You will need to trim the pads
I just did the swap over the winter
I went with gm performance cross drilled rotors front and rear with v2 6 piston calipers up front
2005 CTS-V Maggied
Thanks!
This is what I did.
http://www.cadillacforums.com/forum...-v-performance/479737-v2-calipers-v1-how.html
