1 - 13 of 13 Posts
All of them
UUC steel braided brake hoses are now availible!! they are availible in a "clear" cover over the stainless steel line or red. price is $145.00 plus shipping. my first bulk order of them will be here in about a week and a half, so get your orders in now. the attatched picture is of the protype set and does not have the plastic cover over the lines, the real hoses will have them.
All of them
Discussion Starter #2
here is the technical write up from UUC....
Stainless steel brake lines for improved braking performance
These lines are 100% MADE IN USA and DOT-COMPLIANT
Original brake lines are rubber and can expand under the normal pressure of
use. This expansion of the brake line negatively affects the brake caliper
piston travel, and makes for mushy pedal feedback. Likewise, thermal
effects (heat) encountered during performance driving can soften the OE
rubber lines, making the pedal even softer.
Stainless Steel Brake lines are used to "performance tune" your braking
system.
Inner Teflon® line is covered with woven stainless steel braid that will not
expand under pressure nor soften under heat. The advantages include better
brake pedal feedback and a firmer pedal, along with superior brake
modulation. Results will be immediate.
Technical features:
* Direct fit replacement for OE lines, uses original brackets and connects
directly to calipers. No adapters required.
* Fully compliant with DOT Standards (MVSS-1006).
* Lines burst-tested to 6000psi (maximum tested pressure from normal braking
system is 1200psi)
* Teflon® inner line covered with a woven layer of stainless steel and
covered in an abrasion-resistant material (translucent plastic covering).
* plastic end pieces protect assembly, no exposed steel fibers to stick
fingers.
those are sweet... but i still have the goodriches i bought a while ago...
05 Redline CTS-V
i'll take a set of red ones as soon as my ******* surrenders my checkbook ....the pucker factor is still on 10 from buying those headers
2016 ATS Premium 6-spd MT
Yeah, sometimes it feels like the day after eating a plate full of roasted jalapenos or a huge helpin' of some good pico de gallo. Sucker's just reall relunctant to open up. :rolleyes: But, those headers ... ahh-h, those headers ... they're worth it! :thumbsup:
Hey, Luke, is this price the every-day price so it's gonna be good for a while or is this some special short-lived promotional thing?
All of them
Discussion Starter #9
this is the every day price.
All of them
Discussion Starter #12
The clutch line is still being looked into. UUC is trying to find the fitting on the trans end (its a little unique). they havent given up though so stay tuned.
1 - 13 of 13 Posts
