Having a Magnaflow installed tomorrow and plan on doing the B&M with UUC/Lindsay bushings this weekend on my own.
I plan on doing the installation “from the top” except for the one shift linkage bolt that attaches to the bottom of the new shaft.
I hope that this isn’t a stupid question but…I’ve read up on the difficulty of the UUC/Lindsay bushing installation and I’m confused by one thing…on the factory set up, the base (thickest part) of the bushing is towards the back of the assembly (see attached pictures).
http://www.cadillacforums.com/forums/attachment.php?attachmentid=30958&stc=1&d=1179414625
http://www.cadillacforums.com/forums/attachment.php?attachmentid=30959&stc=1&d=1179414625
Is this how the UUC/Lindsay bushings should also be installed? If so, it looks nearly impossible given the limited room to work with between the shifter “plate” and the steel “C” that holds/wraps around the bushing. Do you slip the bushings in at an angle so the base is facing the back of the car or do you install the UUC/Lindsay bushings with the “base” of the bushing facing toward the front of the car?
I hope that I’ve explained myself well enough for some replies. Thanks for any help that you can provide.
