1 - 2 of 2 Posts
'05 Deville DHS
Need to remove the bottom outside mounding on my 2005 DHS to replace the quarter glass.. Before I tear it up anymore, is there a way to remove the outer lower chrome seal? How?
Solved. Remove the 7 or so small screws along the inside of the trim to pop the top outward. Wiggle the new window in and screw the trim back on. It's a bear, but do-able. Shove the rubber molding along the top and front of the frame. Reinstall the plastic inner cladding making sure to hook it into the rubber seals. Fight the inner panel on. Done.
That's part of the reveal molding assembly - the metal/rubber around the entire window opening and the pillar trim panel. Not sure how to remove it on your car.
1 - 2 of 2 Posts
