I just put a delco remmy in mine, $130 from advance w/62mm pulley. Double and tripple check which size pulley you need OR get a new alternator WITH the correct pulley for the alternator, if not, it's possible a shop will put whatever size you have on the new alternator and if that's say a 57mm pulley and the new alternator needs a 62, you'll be overdriving the alternator and it could burn it out faster / damage it, alternatively if yours has a 62mm and it's put on a 57mm alternator you could end up with an underdriven / low voltage setup. $305 w/labor isn't bad IMO, that sucker was a PITA even with the stupid access door, I spent 2 long hours fiddling with getting it dropped w/o punching the radiator, otherwise it's an easy job for someone with small hands...
