1 - 20 of 40 Posts
-02 STS
Hi
I'm wondering if I can use the service update CD with GM part. no. 19115256 for my -02 Delphi (Denso) DVD-based stock navigation unit or do I have to use another one?
The reason I ask is that since this car is sold in Europe I have the RPO code
U3S.
Your domestic ones have the RPO code U3R or U3Q.
Any info would be appreciated since the dealers here in Sweden hasn't got a clue..
Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
why update it?
the software update was only used in the event a power flux or the user accidentally flashed the hard drive...
you gain no new features or options with the update
-02 STS
The reason I want to update it is because a service bullletin from Cadillac and Corvette Europe says that vehicles older than -07 must be updated in order to use navigation maps from -07 and newer...
-02 STS
The question I really need an answer to is if it's going to hurt anything if I choose to upgrade the firmware...I was thinking U3S with different options than your domestic ones can go bad if I choose the wrong update CD.
Or is it just one for all three RPO:s..the U3S, U3Q and U3R?
Banned
Ohhhh...
hummm
the problem lies in the fact that p/n is discontinued and probably will not be found anywhere
i have a copy of the disc along with the upload instructions and have used it to flash bricked navs but idk about a UK nav if it was Japan id say sure but the euro nav had the different am/fm band tuner frequencies....
your BEST bet is to pull your nav
the instructions i have state the software can ONLY be sure to flash navs with these part numbers
25734875
25743430
25744040
25755059
25764007
if your navs GM part number matches any of them
-02 STS
Ok, I already have a copy of the disc on it's way home :)
But I was hoping not to pull the unit since I don't want to scratch or break anything..
How do I remove the unit? If I can just get the top plastic of in one piece then the rest will hopefully be obvious.
-02 STS
Besides the radio frequencies are there any other risks? In that case I'm willing to give it a try since I don't use the radio that much...
Banned
whats your email
i can send you full gm esi instructions along with pictures
do not i repeat DO NOT attempt the upgrade on the unit if yours does not match the part numbers provided, or else youll have a nice sized $4000 dollar brick on your hands...
-02 STS
Discussion Starter #11 (Edited)
Ok. I pulled the unit and wrote down the part. no.
Gm no. is 25740478
Denso no. is 462200-8032
So it seems that this software update is not suitable for my system..
There must be updates since they are selling maps for my STS..
I checked and according to the TSB i have from Cadillac & Corvette Europe
the same maps are used in STS 02-04. SRX 04-06, XLR 04-07.
But of course they don't know what I'm atalking about..
Banned
have you tried asking a dealer about what is needed to do the update?
also could try and contact GM Europe for intel
-02 STS
Discussion Starter #13
Some dealers says that it is not possible to use a map newer than 04, this is because the main parts importer/distributor for GM says it can't be done.
They have interpreted the column in the TSB that says Seville MY02-04
with February 2004 for road map data....I know since I tried to tell them that there are maps for 2007 and 2008 out. They tell me I'm wrong but still I have a 2007 road map disc right here.
Others says that it can be done but they never manage to get info about the updates...
I've tried Cadillac Sweden with no luck and when I tried Cadillac & Corvette Europe they referred me back to a dealer.
I've tried most of the dealer in the souther and middle parts of Sweden...they either don't know or tell me that there are no maps newer than 2004 to my car...funny since I have the part. no right here for a 2008 map to a 2002 STS..
Do you think it's done via a Tech2?
Banned
def not done via tech II
Denso radios can only be serviced by Denso Japan hence why there are software updates via disc
is you car under warranty still?
-02 STS
Discussion Starter #15
No warranty..
Hmm, did I say that I've been in contact with gmnavdisc? They told me that Cadillac had the information not them..but when I read TSB:s they all refer back to gmnavdisc.com.. :crybaby:
Should I contact Denso?
Banned
Denso is of no help trust me on this
if you were under warranty i was gonna say run the disk anyways and if it locks go to the dealer act stupid and get a new nav....
idk what to tell you at this point i mean im very experienced with these systems but i dont wanna tell you something that locks up your navigation system...
-02 STS
Discussion Starter #17
Hmm, I've heared that the software update supposedly are on the new map DVD:s (from dubious sources I might add).
When I looked at the file structure on my old discs the structure looks like this:
Volume is 464210-6040A
ALLDATA.KWI
DICVCE56.KWI
INDEXDAT.KWI
KGRPDAT.KWI
METADATA.KWI
SPEC.KWI
VERSION.TXT
VIRTUAL0.DAT
VIRTUAL1.DAT
The new disc looks like:
Volume is 464210-6530
05.CMP
ALLDATA.KWI
DICVCE56.KWI
INDEXDAT.KWI
KGRPDAT.KWI
METADATA.KWI
SPEC.KWI
STDKIR.KWI
STDVCE.KWI
VERSION.TXT
VIRTUAL0.DAT
VIRTUAL1.DAT
I was hoping that the odd files had something to do with the software update...
-02 STS
Discussion Starter #19
Yes I've tried the new map DVD and everything looks fine except that I can't enter any adress, select POI:s etc. all menus are selectable but they don't do anything.
Just as the disclaimer on the back of the map-DVD says
"For vehicles built prior to 2007, a service CD update may be required to use the DVD map disc.
If the adress destination entry no longer functions with this map disc, please see your dealership for the service update"
The map DVD loads but the player goes on and on just if it was stuck or something. The arrow doesn't move when driving either. When I switch back to the old map DVD everything works just fine..
-02 STS
Discussion Starter #20
Is the upgrade disc only updating the navigation unit? Or is it updating anything else? I.e only the navi, not the radio, TV, etc?
1 - 20 of 40 Posts
