1 - 8 of 8 Posts
1981 Seville Diesel, 1981 Seville V864
1981 Seville 368 DFI
Car runs great except on a partially warm restart, then the idle speed fluctuates from 300 to 700 for about a minute. I have replaced the
ISC motor TPS, temp sensor, intake air temp sensor, egr, ignition module, and set everything up by the factory manual. If it stalls
enough times I get a check engine light, code 33. then it idles fine, but I get no cruise, or modulated displacement until I clear the code.
If anybody has any ideas, I welcome them
thanks
Re: unstable idle partially warm
Yes, also have installed a rebuilt ecu
Verify fuel pressure is at spec. Could be too lean upon restart. There's a "sock" or pre filter attached to the bottom of the fuel level sender in the tank. If it's original that could be it.
Thanks for that idea, I can see where that could do it, certainly nothing else I have tried has made a bit of difference, although the car runs better and better (except for the idle issue)
I will let you know what I find
Verify fuel pressure first. If it's below spec suspect the sock and/or the fuel pump itself.
Problem solved. Fuel pressure was on spec, changed fuel pump, sock and filter anyway
It was the Manifold Absolute Pressure Sensor. Also changed the baro sensor since I was in there. Cleaned up the Modulated displacement operation as well.
(as clean as it can be anyway)
Thanks for the ideas
seems like it's always the LAST part I try before I can fix anything!
1 - 8 of 8 Posts
