Today i was looking under my hood checking things out and i noticed a broken wire towards the bottom of the block just under the water pump area. I'm not quite sure what it's for but i'm assuming it has something to do with the thermostat? i also noticed some fluid in the area on the motor also which i'm thinking is my water pump leaking. Maybe someone else can correct me if i'm wrong in my assumptions or verify if im right. Thanks in advance.
(In these pictures the circle is the broken wire, and the square is fluid leaking down the block)
