2013 ATS Performance 2.0T M6, 2016 Mustang GT Performance Pack, M6
I'm moving an 80", 113 lb. TV from one room to another. I bought an articulated mount that allows a 24" extension and when I went to install it, I find the wall has 24" stud spacing. Been in this house 33 years and every other wall I've checked had 16" spacing. The mount requires 16" spacing.
Options that come to mind:
Similarly, if I bolt a sheet cut to extend past two studs and taller than the mount, it would be hidden but wavy sides and other than 90 degree corners would bug me anyway. What would be the best material?
I'm worried about even a lot of drywall anchors plus one stud or a sheet of anything bolted to the wall can take the load of a 113 lb TV extended 24 inches from them. I find massive load ratings for anchors but they say those are sheer loads. I have no idea what is strong enough for that much weight on a two foot lever (other than two 2x4s studs the mount is designed for).
Option 3 would be the one well within skill set and tools.
Ideas, opinions?
- Buy another expensive mount (1f 24" stud types exist) and try to sell this one. Online store isn't open today yet but expect return unpractical since the mount weighs over 50 lbs.
- Cut out big section of drywall between two studs and add horizontal 2 by Xs between them where the upper and lower mounting points will be and reinstall the drywall.
- Bolt one end of the mount to an existing stud and use a $#!& load of the strongest drywall anchors the full width of the mount top and bottom (slots run most of the length).
- Bolt a sheet of something to two existing studs and bolt the mount to that sheet.
Ideas, opinions?
