1.1989 Fleetwood Cadillac
2.Hazard works but there is not a strong sound
3.Left and right blinkers do not work.
4.All fuses underneath on the left side of the steering wheel are all working and solid.
I believe it is either the contact in the steering column or the relay for the blinkers...but I cannot find the blinker relay under the hood or underneath the steering wheel.
Does anyone know specifically where it is and can take a picture for me? I know its alot of hassle but, frustration is setting in...
any other ideas or suggestions wanted..
Thanks:worship:
Unicycle
are the blinkers workiing at all?
the blinker relay is a round silver thing under the dash on the left side next to all the fuses... you can't miss it and replacements from Advance/Auto Zone are like $6, pops right in.
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
There are 2 blinker relays under the dash attached to the steering column.
Remove the underdash trim panel cover and you will see them clipped to the steering column.
This has worked for me.
Post your results.
Discussion Starter · #4 ·
Hey...i found it...under the column of the steering wheel with two metal clips holding them....had to get some plyers to pull of the wire but MY BLINKERS WORK NOW!!!!..no more hand signals!!!!
