I think you are just talking about replacing the bulb. To do that, you should be able to remove the plastic cover over your turn signal with a torx driver and just replace the bulb after you remove the plastic housing. Is the bulb what you are trying to replace?jabrum said::bighead: Hi My turnsignals just stopped, purchased a
flasher unit but where does it go? My husband just
looked in the area around the fuse box, could not find.
Thanks Joanne
