2012 escalade ext
I have a 2012 escalade EXT 13,000 miles. Thinking about placing twin turbos. Anyone
with any feedback or experience? Thank you ! Gary
All Escalade Premiums, '16 ESV, '13 ESV, '10 EXT
Before I would start down that rabbit hole, what's your experience? Based on that YMMV...
2012 escalade ext
I have owned several performance type automobiles. Have noticed every one that had turbos performed well
and got better mpg.
and got better mpg.
Cool, so yeah if you're more of a driver than a fabricator take it to hennessey http://www.hennesseyperformance.com/escalade-62-hpe1000.html. As far as I know they are the only shop doing commercial installs of TT setups for the escalade. Everything will will require massive amounts of fabrication and skill.
And yes turbo cars are usually solid performers, but the primary reasons they get slightly better gas than their NA counterparts is they are usually lower compression motors so use less fuel while out of boost. You will not improve fuel economy by turbocharging a high compression engine, you're more likely to lose overall economy due to the fuel burned during acceleration, fuel economy improvements in low compression turbo charged cars are only realized out of boost.
