1996 elderado etc,1960 chry 300-f,1992 buick rm
Hi, numerous led lights not working, how would I gain access to the lamp assy, and can I replace the led lamps that dont work or replace the whole aSSY ON THE TRUNK LID. Thanks Tony.:tisk:
2008 DTS Lux III
The individual L E D's are not replaceable. I bought the whole light bar on ebay for about $150. I was able to replace it myself with a minimum of work in half an hour with a couple of simple tools. Need to carefully access the rear from inside the trunk by carefully lifting the inner lining. Do not over-tighten the bolts. I have been careful when closing the trunk. I'm convinced that slamming the trunk lid is what does them in.
1997 Mercury Grand Marquis
Emphasizing this.
When I replaced mine I tightened them down a bit to snug and sure enough some of plastic that holds the screw lugs cracked from the housing. Also make sure the gasket material seals up against the trunklid or you could get leaks
