2012 CTS 4 performance package
I have replace the switch on my 2012 CTS and still not working. All other switches work fine. ( the trunk release on door and the fob both work fine ). Dealer wants $85 to diagnose the issue but it work guarantee results. Anyone had this issue before
Discussion Starter #2
I have replace the switch on my 2012 CTS and still not working. All other switches work fine. ( the trunk release on door and the fob both work fine ). Dealer wants $85 to diagnose the issue but they wont guarantee results. Anyone had this issue before
The "membrane" style exterior trunk release (above rear license plate) has been known to fail. I would also inspect the wiring for breaks or damage.
2013 Black Diamond CTS4 Premium Coupe (sold-09 CTS4 DI Black Raven/Ebony)
Use a multimeter to test for continuity to verify the replacement membrane switch is making contact properly. If it is, then as Long said, it's a wiring issue. Most likely where the wiring harness bends when the decklid is opened. Search the forum, it's a common issue and easily fixed.
If your idea of joining a broken wire is twisting the wires together and putting tape of a wire nut to hold them together, then best to have a professional make the repair as those methods will not last long in the mobile environment.
