Cadillac Seville STS 1999
Hello all this is my first post. I love this site and it has already helped me out a lot. I have a 99 STS with 171,500 miles on it. It runs great but occasionally the whole car will shut down. It will restart once I put it into park and put the key to off and then turn it back again. I checked the trouble codes last month with a scanner, before I found out how to access them on the dash. These were from the scanner.
P0300
P0404
741- torque converter Performance
1376 ignition ground circuit fault
These are the ones that I found today:
C 1243 History
U 1255 History
U 1064 history
B 1805 history
B 1652 history
P 0113 current
P 1111 current
P 1599 history
P 0603 history
B 1327 history
I was able to clear most all of the codes, and then I drove the car and the only ones that came back were 0113 & 1111.
The car is sometimes hard to start and may take two tries. Ignition switch problem? Battery?
thanks for any help
2008 SRX
Your air temp sensor in the air filter snorkel is probably unplugged, but it's not the root of your problem. A bad ignition switch is a likely cause. See if you can duplicate this by fooling around with the key while it's running. Ignition switches are very common. I'm not sure I've ever seen one cause a stall though.
????? Isn't the IT part of the MAF plug in a '99 STS ? The thermistor is on the inside of the MAF housing and is connected through 2 pins on the 5-pin connector........if that's unplugged, the car will NOT run. Some of the '99 - '03 series did have ignition switch problems/warranty work.
Not so careful as I thought. I forgot to put the plug for the inlet air temp sensor in after cleaning the air filter. All trouble codes are now clear. It has been raining a lot, and my check engine light came on after I cleaned under the hood. That is gone too. Now that I know the quick way to check codes, I am going to keep up to see what happens. I could not duplicate a stall by fooling with the ignition while running. I read another post where someone with a 00 Deville had a mysterious shutdown, that from the description sounded exactly the way mine happens. Will have to look for that thread again. Thanks for the help.
