1 - 10 of 10 Posts
I have a 2008 cts. I bought the car knowing it had a slight transmission issue, it slightly bumps into gears when accelerating and when coming to a stop. Im getting transmission switch codes
P0872-switch 3
P0877-4
P0989-5
P0856-traction control torque request
Go ahead, blame me. Everybody does 馃檮
Post up a pic of your fuse box and we can compare.
Is this a RWD or AWD CTS?
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
I bet that has something to do with the V8 models.
I was hoping to pop in a few fuses and see if the tranny will shift better, haha never that simple. I guess its just the pressure switches failing in the the tranny.
2012 Silver Perf Coupe awd ; 2013 Silver Premium Coupe- awd: currently 2012 Premium Coupe -awd
If you look carefully you will notice either no metal contactors or contacts on one side only on most of them. As flash sez- there are many circuits that will not be used on a base car.
Have you change the oil in the transmission? I also like to use the Lucas transmission additive
1 - 10 of 10 Posts
