Don't worry, I can still hunt you down
Don't worry, I can still hunt you downOh, Ron, btw ... we moved ... no forwarding address.
Here are a couple of pic's from inside the trans. One shows the reverse gear that attempted to weld itself to the shaft. The other, which is a little dark, is all the shavings stuck to the magnets on the bottom of the trans.
To the best of my knowledge the level was correct. It was Mobil 1. The only thing I can think of is that it was near 0* F that morning and the car had been sitting at the airport for a week prior to my driving it that day. I did let the motor warm up before taking off but the trans was still cold. Shouldn't have been a problem but may have been a contributor.Was the fluid level up to snuff? What kind of fluid?
These questions may have nothing at all to do with the bearing failure ... just thought I'd ask.
Thanks,Making it easier on us...
Sounds like mine. This seems to be a common issue unique to the design of the tail section use only on our cars in the T56. The reverse synchro and gear section gets oil starved and the synchro welds itself together. In my case I was driving in sub zero temps after having my car sit at the airport for a week in the cold. The tail probably didn't see any oil before the synchro seized.andrewbibona said:Fml, my 2004 CTS-V just did this same exact thing! Neutral is now reverse and 1st and all other gears feel like two gears fighting (reverse and forward) 2526268100 with any help please!!
This would be my guess. Decently big job just getting to it, though ... remove tranny, crack it open, do the syncro swap, reinstall the tranny.... Will I only have to change out my reverse syncro? ...
I'll give you a call if I don't see a reply to this post but I'll document the answer here for future reference:Please call me if you have any more knowledge on this matter. 2526268100. Is it rebuildable? Will I only have to change out my reverse syncro? Cars in the shop now and don't wanna be dicked over. Please call so I don't miss the post. Thank you for anyones help!!
