Transmission shudder
551 views 11 replies 5 participants last post by  Wojciech
Good evening,
I was trying to find out on the forum is the dreaded shutter is as prevalent as it is on the Facebook forums.
#2 ·
I presume you mean "shudder".
I don't experience any issues on my 2020 Sport. ~60k miles on the odometer. Most issues reported here are related to valve body failure and those have been reported for 2023-2024 model years.
#3 ·
2020 here, had the shudder when I got it around 45k miles, dealer found damage to the torque converter so that was replaced along with fresh fluid, all good since, albeit that's only like 6 months, 5k miles.
You'll hear about it more on the later years like Northey's talking about, where there's a manufacturing defect in play, but as far as I can tell all years are susceptible to the weak sauce ATF breaking down and damage cascading from there the longer it goes unaddressed.
#4 ·
My 2020 has some shudder when going uphill, but only if the transmission fluid temperature is above 60°C. Below that temperature, everything is fine.
I’m going to replace the fluid soon and update the transmission software, since there’s a TSB for a software fix related to shudder.
If that doesn’t help, I’ll try adding a 'shudder stop' additive, as others have reported that it completely eliminated the problem.
