1941 series 6227 2007 SRX
Does anyone have an idea of the cause of this issue with my 2007 SRX: It started a few weeks ago ( 84,000 miles), intermittently when braking, I feel a "shudder" through the transmission and the shift lever vibrates forward and back. It doesn't do it all the time. It is a 3.6 V-6, AWD. Could this be an issue with the electronics, or just needs a trans fluid change? Any help will be greatly appreciated.
2005 SRX 3.6
We had precisely the same symptoms after an engine replacement ( 3.6 timing chain failure ) at 51k miles minus -- intermittant, non-repeatable shudder or stutter only sometimes on deceleration and/or braking. I thought it might be a fluid level issue or a controller adaptation issue since the first time this car ever saw WOT was during ring break-in.
Dealer purged and refilled fluid, and the issue vanished.
**2014 CTS4 Sport Wagon-Luxury**
I felt something similar to what you describe and my issue turned out to be new brakes and rotors...I haven't had a recurrence since the 4 wheel brake job was done and I know the mechanics so I didn't get anything the car didn't need...
Hope you get yours fixed up...
Bill
I had been told previous that it is usually warped rear rotors that might cause this...a check of the gumbo (flex disc connector) could cause this if loose but I bet you will find it is the rear brake rotors...
Bill
Thanks for the additional info on the possible brake rotor issue. I have been monitoring the "shudder", and discovered that it begins when the brakes are heated up. The harder I drive and brake, the more often the "shudder" happens. I think
the brakes are the culprit. New pads and rotors are ordered. Phil
good to read and hopefully this gets you fixed up...mine has not appeared since having my brakes done...
Bill
