I have a 2014 XTS with 120k miles, 3.6 paired with a 6T70 trans.
I did spark plugs and a transmission fluid flush.
I have what feels like a shudder, in 5th and 6th gear under light acceleration.
I do not have cel or tcm code set.
I’ve narrowed it down to what I think is a TC lockup problem.
The shudder will happen at any speed but only in 5th & 6th gear, it will happen at lower rpm 1000-1500rpm, and under light throttle the car will begin to shudder as if the TC can’t make up its mind on staying locked up or not.
I believe it’s a lockup issue because it’s only in 5th & 6th and the cars resolution, is to raise the rpms to about 2k or higher, so I believe it’s disengaging TC lock up.
I’m looking for any input as to whether it could be the TC or the control body, but once again I don’t have and codes to go off of.
