1976 Cadillac Brougham D'elegance
Hey guys
My oil pan is leaking, I ordered a replacement Delco filter which came with a cork gasket.
It looks cheap, and Ive heard cork tends to leak...Should I buy rubber gasket?
1977 Eldorado, 1973 Sedan DeVille
If you use the cork gasket with Permatex #2 Form-A-Gasket sealant you will be just fine.
It says on the manual never use gasket sealants of any kind...Thanks for your input
Something German S550, 69 Eldorado, 68 Impala, If I tell you the rest, well
People that use cork gaskets that leak is usually due to over torque bolts or warped pan. With a properly prep surface and a flat pan you will be good rubber or cork for the trans pan. Use a little Vaseline on the gasket to hold it in place as you mount it, and don't over torque.
But with the cork you will need to go back and re torque the bolts.
My Acdelco filter came with a cheap looking cork gasket, should I buy a rubber gasket?
While you have the pan off check for flatness around the bolt holes. If someone over tightened and it's not flat new gasket will leak no matter the type.
Personally I would use a rubber gasket.
