I am looking into buying a 95 SLS that the owner says does not shift out of second. That's all the ad says and I have not been able to talk to him yet. Ebay ad. Not sure if going from 1st to 2nd or just stuck in 2nd. Any thoughts? Any service bulletins or the like? Any help is greatly appreciated. -------silentmike
2005 CTS-V, 1994 Infiniti Q45
Its gonna need a new tranny....... You may get lucky and it could be just a clogged filter (unlikely at this point), but chances are its gonna need replaced anyway........
I think what the ad means is it shifts from 1st->2nd, but wont go from 2nd--> on.........
You more than likely DO NOT need a new transmission!!
First try cleaning the wiring connections to the transmission. Usually shift problems are due to shift solenoids though. Try pulling up the codes
There are 2 solenoids, an A and a B. Seems reasonable to change both while you are changing one or the other.
The solenoids come in a solenoid kit that contains both solenoids and new bracket for around $50.00. The tranny shop I use only charges $75.00 for installation. One dealer I know wants around $270.00 to install. The price is too high. It only takes about an hour to change. You drop the bottom pan which drains the transmission fluid and there they are, change them, clean the screens, put the bottom pan back on and refill with tranny fluid. Simple!
And now you know......The rest of the story!
Depending on your level of expertise....Here's how to check the electrics on the trans.
1
Install the J 39775 Jumper Harness to the transmission side of the 20-way connector.
Using the J 39200 Digital Multimeter (DMM) and the J 35616-A Connector Test Adapter Kit, measure the resistance between terminals A and E (1-2 shift solenoid valve).
Is the resistance within the values indicated?
19-31 ohms
Go to Step 3
Go to Step 2
Disconnect the internal transmission harness from the 1-2 shift solenoid valve.
Measure the resistance of the 1-2 shift solenoid valve.
19-31 ohms
Go to Step 13
Go to Step 14
3
Measure the resistance between terminals B and E (2-3 shift solenoid valve).
19-31 ohms
Go to Step 5
Go to Step 4
4
Disconnect the internal transmission harness from the 2-3 shift solenoid valve.
Measure the resistance of the 2-3 shift solenoid valve.
19-31 ohms
Go to Step 13
Go to Step 14
5
Measure the resistance between terminals T and U (TCC PWM solenoid valve).
10-15 ohms
Go to Step 7
Go to Step 6
6
Disconnect the internal transmission harness from the TCC PWM solenoid valve.
Measure the resistance of the TCC PWM solenoid valve.
10-15 ohms
Go to Step 13
Go to Step 14
7
Measure the resistance between terminals S and V (A/T ISS).
1300-1950 ohms
Go to Step 9
Go to Step 8
8
Disconnect the internal transmission harness from the Automatic Transmission Input Speed Sensor.
Measure the resistance of the Automatic Transmission Input Speed Sensor.
1300-1950 ohms
Go to Step 13
Go to Step 14
9
Measure the resistance between terminals L and M (TFT Sensor).
158-4020 ohms
Go to Step 11
Go to Step 10
10
Disconnect the internal transmission harness from the Automatic Transmission Fluid Temperature Sensor.
Measure the resistance of the Automatic Transmission Fluid Temperature Sensor.
158-4020 ohms
Go to Step 13
Go to Step 14
11
Measure the resistance between terminals C and D (PC Sol. Valve).
3-8 ohms
Go to Step 13
Go to Step 12
12
Disconnect the internal transmission harness from the Pressure Control solenoid valve.
Measure the resistance of the Pressure Control solenoid valve.
3-8 ohms
Go to Step 13
Go to Step 14
13
Replace the Automatic Transmission Wiring Harness. Refer to Automatic Transmission Wiring Harness Replacement.
Is the replacement complete?
System OK
14
Replace the component.
System OK
