Transmission line leak need the name of this part
1 reading
2.6K views 8 replies 7 participants last post by  Ron1978
I have a 1995 fleetwood brougham vehicle leaks transmission fluid. Part looks like a proportioning valve block, it on the right side between the door and the fender. Went to the dealer and asked them if they had the part they telling me the transmission line do not have this block on it & that someone must of added the part ,I explained to them that I seen the same part on the 93-96 chevrolet caprice at the junk yard.
Please help me I'm need this car running asap
#3 ·
Was thinking the same thing, on top I can't remember if it has wires or another line wrapped in the heat shield , either way I will need a 3 way type connector or a replacement part if it's wires. I will post a better picture of the top half when I get back home.
And thanks for your response 🙂
#7 ·
On many models of these years, the tranny's had a line temperature sensor (might be what that is) installed externally. Many of these older metal fittings corrode and begin to leak over time. Take it to a good transmission shop, or find a hose/line rebuilder near you. Most of these parts are impossible to find new, and even if one existed, I'm convinced the knowledge of the local dealership parts manager is usually lacking to find it. Building from scratch is usually the best guarantee you'll get the job done.
#8 · (Edited)
My guess is that the part itself is fine. The fittings are likely fine as well or can be easily replaced. What actually failed because of the rust is the tubing. So, you can repair them just like you repair blown/rusted brake lines.
New prefabricated lines, flairing tool, fittings, unions, tubing, etc. Usual stuff. Any shop should be able to handle that repair. If you disconnect the lines, they will likely fall apart.
#9 · (Edited by Moderator)
My guess is that the part itself is fine. The fitting nuts are likely fine as well or can be easily replaced. What actually failed because of the rust is the tubing. So, you can repair them just like you repair blown/rusted brake lines.
New prefabricated lines, flairing tool, fittings, tubing, etc. Usual stuff. Any shop should be able to handle that repair. If you disconnect the lines, they will likely fall apart.
Vehicle sat for 2 years shocks, brake line now transmission lines rusted out lesson learned. You're right I think it's just the rusted lines the angle I seen the leak made it hard to tell where it's leaking. I never mentioned that the trans fluid leaks on the catalyst converter & causes thick smoke in car & out ,But yes I will change out the lines next weekend or send it to the shop, wanted to replace mostly everything new before I send it for body work & painting . Thanks for the info and your reply (y)
