1 - 1 of 1 Posts
1990 Cadillac deville
Is it possible to correct or replave the throtte valve without removing the control valve assembly, I understand that I will most likle have to remove the pump assembly. However since the throttle valve is right there when you remove the transaxle side pan cover I was thinking I could access the throlle valve and contol valve assembly with removing the transaxle from the car. is this a possibility?
1 - 1 of 1 Posts
