1 - 14 of 14 Posts
Just had the "chuggle" mod done to my 05 V8. What a difference it makes. Like others have said,"It now shifts like a caddy should". Thanks for the info on a great Forum.
2005 STS-4
Has anyone noticed any difference in the gas mileage after doing the transmission software update.........talking about the 2005 STS4 in particular.
Thanks,
Tom
2005 STS-4
Just by chance did GM.....Cadillac..........have the factory fuel set lean for better mileage and that is what is causing the Chuggle and doing the up-grade to solve the problem could have set the fuel richer to eliminate the chuggle and this was a fuel releated problem all along and not transmission related???...........Just a thought. Was talking to a guy yesterday with a Ford F250 that was sent a bulletin from Ford to have the same kinda problem fixed with a re-flash and after he did, the fuel mileage lowered my 3mpg....he wanted it changed back and was told after you re-do it it can't be put back.
Thanks,
Tom
2005 STS4 V8
Interesting thought--but it's most definitely transmission related.
If I were you, I'd go ahead and get the update :) No noticeable change in performance or efficiency.. only a smoother drive.
2006 STS 1SG & 2007 STS 1SE
From some of the older threads, I got the idea that the TCM upgrade also increased the tendency of the transmission to shift-up while coasting at slow speeds. I like the way my 2006 AWD (5-speed) holds the gear and keeps the converter clutch engaged when coasting at slower speeds. When I stomp on the gas, she flies.
My wife's 2007 RWD has the 6-speed. It seems to seek the highest acceptable gear for any speed. When you stomp the gas, it has to downshift more gears. It doesn't seem as quick but this could be an illusion.
I know the mileage differential is bigger than I expected (5 MPG). I think it is the sum of 300 lbs more weight, more mechanical resistance (two more differentials & CV joints), lower gearing, an extra gear and the TCM program.
STS
Is the trans software update free? If not, how much does it cost?
ewill3rd may know better but I had it done under GMPP warrenty because I went in there complaining of "chuggling" and there is a TSB about it. I think it should be an hours labor at most though if you had to pay for it.
1 - 14 of 14 Posts
