After reading through tons of information here on 4th (OD) slipping I am quite certain that it is my shift solenoid(s). Seeing as it is just 4th gear slipping out and even a local tranny shop confirming that it is most likely the problem based off the fact that the mechanic says it is usually what happens on that tranny. Local shops want to take the tranny out to do the job though so they want around 1k to do it. So before I take the job on myself I wanted to confirm one thing. I do not have any check engine light/DTC code for the shift solenoid or anything tranny related. I did a real code scan with a code scanner. Should I take this as a clear indication that it is NOT the shift solenoid(s)?
