fleetwood fwd and deville rwd
I had wrote a message about the Tranny and that in 2 years when I was at a stop and then put it to the peddle it would not go.. Only happened 4 times in the last two years...ok I thought that my neighbor the flushed the Tranny. He has just advised me that he only drained all the fluild out replaced fluid and replaced the filter...So now I guess the next step would be a flush or someone else told me that a hose might be clogged and to keep driving it or go to the store and get some unclogging stuff.. Should I take it to a Trannsmission Shop? Any ideas of what is really going on??? I do not have a clue I thought changing and flushing were the same thing tells you how much I know..?? ....Thanks........
2003 Escalade
I wouldn't flush it if I were you. I did the same thing and $1650.00 later found out you never flush a a cadillac trans. Your neighbor did the right thing. It could be so easy as a fuse. I would take it to a pro before you really mess it up..
