The snow started flying up here, and the traction control seemed to be working like it should. However, on my way home from work tonight; the traction control seems to be engaging when it's not supposed to.
I was traveling on a slightly wet road, and had plenty of traction; but around 57MPH, the "traction active" message came on. I could tell it was engaged, because I had a noticable loss in power. I'd let the car coast down till it was under 55MPH, and the car would act normally. However, once I'd start getting above 55MPH; the "tracton active" message would pop up, and the car's power would be cut once again.
The weirdest part of this, was when I was going downhill. My foot was off the gas, and I was coasting around 45MPH; and the "traction active" message came on again. I couldn't believe that the traction control would engage when I was coasting downhill with my foot off the gas! :banghead: Is any of this normal? I've driven these roads in the rain, with the road wet and never had this problem before. :hmm:
I know that I can go into the "PCM Overrides" and disable the traction control; but I'd really rather not do that, as it really helps us get going at lower speeds. If I do have to override the traction control, would that disable the ABS as well? Or can I override the traction control without disabling the ABS?
