Does anybody have any ideas about this, I want to make sure that this is the same problem and not a new one. I've tried reseting everything and unplugging the battery for over 30 minutes.Thanks.After unsuccessfully attempting to remove the ebtcm, I re-tightened the screws and reconnected the wiring harness. But now the ABS warning light is constantly on, which has never happend before. There are no new codes that I can see that would have caused this light to come on. What is causing it, and is there any way to make it go off?
Thank you for your reply. So is the EBTCM under the air cleaner on the right side? Ive read where people have said that that is where it is but Im not sure about the 1996 model. I took out the air cleaner and didnt see anything, so I must need to remove something else. Also in the service manual I have it says that the EBCM/EBTCM is located in the trunk. How do I know where to look? I'm also unsure of where the PCM is. Once I find them should I simpley examine and reseat the connections? Thanks again.
