1 - 10 of 10 Posts
2006 Cadillac STS V8 RWD
While I was driving to work this afternoon, I had quite an incident.
I had my traction control off, but the stability system was still active.
when I entered the round about and as I was about to exit, I accelerated the car, like I would normally do, but it span, it went around 280 degrees!
I tried to steer in the direction of skid but there was no hope to bring the car back, so I slammed on the brakes and the ABS kicked it, eventually stopping the car.
Why didn't the stability system kick in? Moreover, after the car came to a complete stop, the engine was off. Why would the engine cuts off? Is that a safety feature? Don't I need the engine to remain ON so that the Stabilitrack will work?
2006 STS 1SF N* RWD NAV F55
WOW ! Koz you pull NO punches.
I can't believe you are complaining about traction, when you had the traction
control OFF ? I am glad it was ONLY an incident, and NO damage was done to
your "CADILLAC". I have to agree with Koz, With the following change.
"If" you are going to drive like NASCAR, and understand I "DO" every time I get
out there,and sometimes we get ourselves into unusual circumstances.
Let the machine work for you, and have it ready for anything, so it can
Help you get out of it, SAFELY ! If you were NOT on Snow or ICE,
I certainly would be thinking about new Tires that have a better traction
than the ones you have on there,and the pressures are correct for them.
I just ordered tire pressure indicators, that fit on the valve stem, to let me
know when any of them are "LOW" with an Amber or Red color to let me know
when it is low. Yes, I don't have TPM.If you like this idea, they are about
$ 1.00 a piece and a little shipping, look at when they alarm, and not the
exact pressure. Some alarm at 25 % and 30 % , so for 30 lbs, you would have to have 32's to alarm at 28. No one here probably knows what you asked for in your post. But Good Luck. and Happy SAFE driving. :cool2::cool2::cool2::cool2:
I would think the Stability controls other stuff , like possible rollover, and
not necessaraily skidding, But I could be wrong.....
Thanks for the advise on Safe driving Everybody.
I was looking for information on the engineering processes behind traction control and Stability System. What is the difference? The owner manual mentions that you can turn the Traction Control off, simply by pressing the button, and the Full Stability System by holding it for 5 seconds.
I might be having bad tires, the previous owner put a cheap kind, none of the famous ones, like Michelen or Bridgstones, so this could be the reason.
I am actually worried and don't feel as safe as I was before driving the car, that is why I was asking for advise, not because I want to do dognuts and smoke my tires in an irresponsible manner.
I would really appreciate anybody's help in explaining how the Traction Control and Stabilitrack system works in a technical engineering manner. Does it detect Yaw? ....
G
it detects jackassery, and it looks like it did a damn good job. I hear it only happens when you turn traction control off, and then wonder why the car spun around.
2006 STS 1SG & 2007 STS 1SE
All the Stability Control can do a apply braking to one or more wheels to limit wheel slip. Your car was already out of control and beyond help of that sort.
If your tires are so bad that the Traction Control is annoying enough that you habitually turn it off, replace them.
1 - 10 of 10 Posts
