1 - 2 of 2 Posts
Gentlemen,
I just got my hands on a set of used oem 18s and they came with tpms sensors on them. I am planning to swap over the tires and sensors from my current wheels since they are almost new. On the old sensor, there is a tab that says Press. I pressed and I was able to seperate the sensor from the valve stem. I am not sure if the sensors on my current wheels are the same kind. If they are, it should be an easy swap but In case if they are not, how do I swap the TPMS sensors from my current wheels to the new wheels?
2014 ELR
Two kinds: rubber stem and clamp on. Rubber stems come off with a small torx from the back (and you use new rubber valve stems. Clamp on have the metal stem, and come apart with a socket.
1 - 2 of 2 Posts
