1 - 2 of 2 Posts
2001 DTS
If I'm not mistaken all the 2000 and 2001 Cadillac DeVilles with TPMS use the same 315 MHZ sensor?
Has anyone used any other sensor found on another make/model with success?
For instance, I had no idea this would happen so I didn't bother a relearn attempt: I put 05-06 Equinox wheels & tires on my 09 Equinox and the TPMS started working after a few days. I didn't know the rims had the sensors. I realize this is a later model and probably has advanced capabilities. Then I installed my 09 Equinox wheel on an 07 Impala and did a relearn and it accepted the sensor. Little savings add up.
My DTS needs 3 sensors replaced and it's time for tires.
2001 DTS
Discussion Starter #2
Disclaimer: I haven't attempted usage of any alternate tire pressure sensors listed yet, and some mentioned sensors might even require programming but you'll see in the lists that there are a bunch of alternative vehicles using stating compatibility.
On Rockauto, Schrader being a major supplier shows part # 20117 for my DeVille and the following Alternate/OEM Part Number(s): 25731358, 25773946.
My DeVille sensor dated from 2001 has a embossed # of 25731358
The 01-04 Corvette 25773946 shows similar info.
CADILLACDEVILLE2001-2005
CADILLACSEVILLE2001-2004
CHEVROLETCORVETTE2001-2004
Anyway, I searched 25731358 the number on my DTS sensor and here are just the alternate numbers for VDO sensor SE10001HP listed as compatible:
Alternate/OEM Part Number(s): 10306573, 10354988, 10394110, 10438853, 12768826, 13581558, 13586335, 13589255, 13598771, 13598772, 15102575, 15123145, 15136883, 15163068, 15163069, 15202272, 15254101, 15268606, 15825475, 15921013, 15922396, 19316553, 20922900, 20923680, 20925924, 20964159, 22853741, 22854866, 22959744, 22959748, 25648293, 25731358 (DeVille), 25758220, 25763677 (see below), 25773946 (Corvette), 25774006 (see below), 25799331, 25920615, 25952370, 25981210, 407001AA08, 407001AA0A, 407001AA0B, 407001AA0C, 407001AA0D, 407003AN0A, 407003AN0B, 40700CD000, 40700CD001, 40700CK001, 40700CK002, 40700JA00B, 40700JA00C, 40700JA01A, 40700JA01B, 40700JA01C, 40700JA02B, 40700JK00A, 40700JK00B, 40700JK00C, 40700JK00D, 40700JK00E, 40700JK01A, 40700JK01B, 407703AN0D, 4250A030, 4250A225, 4250B668, 4250B875, 4250B877, 4250B975, 4250C193, 4250C276, 4250D585, 4313054J20, 4313054J21, 4313054J22, 4313057L00, 4313078J00, 4313078J10, 4313078J20, 4313078J21, 4313082Z10, 4313085Z00, 4313085Z01, 4313085Z03, 4313086Z20, 4321182Z00, 4321182Z10, 4727392AA, 4727392AB, 4727392AC, 4727392AD, 4727392AE, 4H231A159CB, 4H231A159CC, 5127335AA, 5127335AB, 5127335AC, 5127335AD, 5127335AE, 5139640AA, 5142340AA, 529331M000, 529332L500, 529332L700, 529332M000, 529333N000, 56029319AA, 56029319AB, 56029319AC, 56029465AB, 56029465AC, 56029479AA, 56029479AB, 56029526AA, 56053030AA, 56053030AB, 56053030AC, 56053030AD, 56053036AA, 56053066AA, 5L1Z1A150AA, 5L1Z1A150AB, 5L7T1A150AA, 68001696AA, 68001696AB, 68078861AA, 68078861AB, 68111696AA, 68137699AA, 68375775AA, 6F2A1A176AE, 6F2T1A150AE, 6F2Z1A189A, 6L2T1A150AA, 7001HPR, 7L1Z1A189A, 8C2T1A150BA, 8C2T1A189A, 8C2Z1A189A, 92186507, 923307, 9L3T1A150BD, 9L3T1A180AE, 9L3T1A180AF, 9L3T1A180BA, 9L3T1A180BB, 9L3Z1A189A, BBM237140A, BBM237140B, BHA437140, CM5T1A180AA, CurrentOEnumber, FE0137140A, GN3A37140, GN3A37140A, GN3A37140B, MN103081, ZZC137140
For 2005 Cadillac SRX #25774006, I got these VDO made listings:
Alternate/OEM Part Number(s): 10306573, 10354988, 10394110, 10438853, 12768826, 13581558, 13586335, 13589255, 13598771, 13598772, 13598786, 15102575, 15123145, 15136883, 15163068, 15163069, 15202272, 15254101, 15268606, 15825475, 15921013, 15922396, 19316553, 20335, 20922900, 20923680, 20925924, 20964159, 22853741, 22854866, 22959744, 22959748, 25648293, 25731358, 25758220, 25763677 (found this part in an '04 SRX tire), 25773946, 25774006, 25799331, 25920615, 25952370, 25981210, 407001AA08, 407001AA0A, 407001AA0B, 407001AA0C, 407001AA0D, 407003AN0A, 407003AN0B, 40700CD000, 40700CD001, 40700CK001, 40700CK002, 40700JA00B, 40700JA00C, 40700JA01A, 40700JA01B, 40700JA01C, 40700JA02B, 40700JK00A, 40700JK00B, 40700JK00C, 40700JK00D, 40700JK00E, 40700JK01A, 40700JK01B, 407703AN0D, 4250A030, 4250A225, 4250B668, 4250B875, 4250B877, 4250B975, 4250C193, 4250C276, 4250D585, 4313054J20, 4313054J21, 4313054J22, 4313057L00, 4313078J00, 4313078J10, 4313078J20, 4313078J21, 4313082Z10, 4313085Z00, 4313085Z01, 4313085Z03, 4313086Z20, 4321182Z00, 4321182Z10, 4727392AA, 4727392AB, 4727392AC, 4727392AD, 4727392AE, 4H231A159CB, 4H231A159CC, 5127335AA, 5127335AB, 5127335AC, 5127335AD, 5127335AE, 5139640AA, 5142340AA, 529331M000, 529332L500, 529332L700, 529332M000, 529333N000, 56029319AA, 56029319AB, 56029319AC, 56029465AB, 56029465AC, 56029479AA, 56029479AB, 56029526AA, 56053030AA, 56053030AB, 56053030AC, 56053030AD, 56053036AA, 56053066AA, 5L1Z1A150AA, 5L1Z1A150AB, 5L7T1A150AA, 68001696AA, 68001696AB, 68078861AA, 68078861AB, 68111696AA, 68137699AA, 68375775AA, 6F2A1A176AE, 6F2T1A150AE, 6F2Z1A189A, 6L2T1A150AA, 7001HP, 7L1Z1A189A, 8C2T1A150BA, 8C2T1A189A, 8C2Z1A189A, 92186507, 923304, 9L3T1A150BD, 9L3T1A180AE, 9L3T1A180AF, 9L3T1A180BA, 9L3T1A180BB, 9L3Z1A189A, BBM237140A, BBM237140B, BHA437140, CM5T1A180AA, DE8T1A180AA, FE0137140A, GN3A37140, GN3A37140A, GN3A37140B, MN103081, SE10001, ZZC137140
I looked at CTS up to 2014 and below is a copy/paste of Stand Mot Prods alternate part numbers. I found the TPM45A and TPM45RA stating "315 Mhz Sensor; 1st Design; No programming required. Install sensor and follow the OEM factory relearn procedure."
Might work on the DeVille?
1 - 2 of 2 Posts
