Can someone please tell me how much weight a 2006 SRX w/V6 and towing package can pull?
Thanks,
'07 - 3.6l SRX RWD, '16 - 2.5l Subaru Outback, '95 - 4.3l S10 pu
4250 lbs for the V92 option. Includes weight of trailer and additional gear. This info should be in the owners' manual
2005 SRX
That towing limit is basically GM saying "Look, this isn't a tow vehicle but if you are hell bent on towing, stay under 1000lbs without the tow package and 4200lbs with the tow package, but we really wish you wouldn't do it."
TK
Thank you. I saw in the manual it was 1000 lbs, and I was looking at an 07 online and they stated it pulled 4500lbs. I then looked at the V6 '06 online and it said 1000lbs. I was a little confused. I am not looking to haul massive amount of weight, but I am considering buying a boat and just wanted to confirm how much I had to work with. Thanks.
2005 SRX N*V8 RWD; 1999 DeVille Concours
Suggest that you consider adding a "supplementary" trans cooler if you do not have the "tow package"; seems to me that the "tow package" adds an additional fan and an additional trans cooler (probably the major need for towing); also seems that there are aftermarket trans coolers.
Good luck
