Interesting:
79 &84 show 176Nm or 130ft-llbs (129.8 ft-lbs so ok)
Service bulletin (June 81): 180Nm or 130ft-lbs (but 180Nm = 132.76 ft-lbs)
They do say they are using a new bolt in the service bulletin but what was their real target for torque? Were they simply rounding? It doesn't seem like enough of a difference for a different bolt class. The bolt heads in the bulletin I hoped would show a recognizable classification but I don't recognize those symbols.
Sequence: Making certain you go up to a partial value first, as stated in the bulletin, seems more significant than switching the 7&8 vs 9&10 positions. I don't understand why that specific change in sequence would matter but I would follow the bulletin and the 84 manual for sequence even though it seems it shouldn't matter. I hope it wasn't simply a time savings in light of the fact it should not matter (a tiny amount of jumping to the other side saved). Remember this was published around the same time GM paid an employee suggestion and made it official GM policy that employee would be spelled "employe" to save one key stroke... and as always when I started to type "employe" without two e's at the end I needed to backspace over one of the e's. Genius! And yes employee vs employe is a true story.
And what of the head gasket difference? They mention how they can be identified but by color. They never really explain the difference to look for.
I also forgot about those darn double sided bolts; the ones with a bracket mounting stud out of the other side of the head. Good luck finding those....
One other thing I noticed is they made certain to advise checking to see that the bolt head could actually contact the surface of the head. They mention chips but I wonder if they cut things so close they had a tolerance issue with depth of threading versus bolt length. Since they want you to check head clearance with a feeler gauge and no head gasket it seems like a good time to run each head bolt in "by hand". If it seems to touch, bolt-head to head-surface, then there should be no question it's good-to-go with a gasket.
Scott
