1 - 12 of 12 Posts
crushing Vs with my Wurm
2013 GT500 - 700+ HP
Fellas,
Anyone know the torque setup on the Hotchkis sways? I did the rear bar this afternoon and will attack the front tomorrow eve. Nowhere in the instructions does it give a torque spec. I just tightened em as tight as I could get em.
Anyone?
F
2005 Stealth Gray CTS-V, 2009 Black CTS-V
I plan on installing these shortly as well, so add me to the curious list.
thanks dreamin... (I had to go out and loosen everything up....but now all torqued and tidy)
F
Lemme know what you think F. By the way, I can almost like Ohio State now that they beat Notre Damn. (yes I spelled it wrong on purpose)
Chris,
The car is under wraps for the winter, I just installed the bars over the past 2evenings. Easy install...Total time = 3 hours w/o creeper and limited work space. You should be able to do it in 2. Looks are much beefier. Will know what it rolls like when I get my new motor put in.
F
Discussion Starter #8
I didnt drop the exhaust...not necessary, just makes it a bunch easier. You can fish it out.
F
Discussion Starter #11
I had my car on jacks...wheels off. Which is better? the one that works best...the wheels on would hamper your efforts.
F
2017 CTS-V
Hotchkis recommends doing the rear at ride height so rhino ramps would be best. The wheels really get in the way when you are trying to remove your bar end-links though. You also need to drop the exhaust if you keep the wheels on.
If you don't have ramps, putting the car on jacks work too. I have no idea what the reasoning is behind installing at ride height.
1 - 12 of 12 Posts
