Out of nowhere, last week my 30,000 mile 2016 ATS began exhibiting the dreaded shudder. At first I thought I had run over a long rumble strip, but I was soon able to provoke it by "feathering" the throttle, and stop it with a downshift, so I knew I had fallen victim to what seems to be a universal problem with the new 8 speed transmissions. I called my dealer and they said to bring it in the next day. Got the car back the same day. The service writer (and the work order) said they flushed the transmission 3 times, and filled it with GM part # 19417577 which is the latest iteration of Mobil 1 LV HP transmission fluid with a modified anti-shear additive. It seems to have worked. The shudder is gone and (subjectively) WOT upshifts feel more positive. Now the question is how long will it last?
One piece of advice I have is that if you begin to experience the shudder, get the fluid flushed and refilled ASAP. The shuddering will eventually burnish the internal clutches to the point where the torque converter has to be replaced. Instead of a couple or 3 hours work, you're talking about major downtime waiting for parts and then major work. Hopefully this new fluid is the effective cure.
