1 - 14 of 14 Posts
05 Raven V
So apparently I own a dragster, the cars rear tires keep coming out of balance. I have never had this problem in the past, even with monstrous ol skool big block engines. Is there anyway (short of bead lockers) that I can keep the tires from slipping on the rims and forcing me to balance this thing every three weeks?
Platinum 2004 CTS-V
They used to run screws in to the tires/rims back in the day. Bead locks, but that would be ugly as hell.
Are your weights coming off? Is that why they are going outta balance ?
05 PLATINUM CTS-V
are your wheels painted/powdercoated?
04 CTS-V with a little hp persuasion device
My car would constantly sling weights over 90. The tire shop would never clean the inside of the wheels to install the stick on weights and they would come right off. Now I clean the inside of the wheel before I go to the shop and no more problems. Just for grins, take a wax pencil and draw a small line on the wheel and the tire. See if they spin. If they do, I dont know what to tell you. My guess is the weights.
06 CTS-V (sold)
My track tires slip on my racing rims (on my Vette) often. Haven't found a cure other than to rebalance them. I do feel that they are more likely to slip early due to the lubricant used to put the tire on the rim. Once they have slipped, they might not slip again. I do use the tire crayon to mark the tire and the wheel to check for slippage. If you do this you'll at least know how much they are moving on you.
2005 Cadillac CTS-V
Be careful,
If your wheels are slipping this could tear up your bead, resulting in constant leaks and possible blow out. Like everyone else said mark the wheel and tire and observe.
1959 Cadillac, 1980 Cadillac,Former 2005 CTS-V; now a 2009 V
that's weird - how come the guys running 600+rwhp aren't having this problem... or aren't noticing it, yet you are?
got to be something else making it happen.
05 CTS-V raven black
The rim and tire were marked, rear seems to occasionally slip about a half inch on the rim. I would assume its from traction control (stabilitrack) turning on or something...
what type of tires?
2011 CTS-V
same here.. never even heard of this before
2006 STS-V
Voodoo, what tire size are you running? I remember from an old thread: http://www.cadillacforums.com/forum...um-2004/154655-monster-v-trailing-arms-2.html and from multiple posts by you that you were talking about going with 315's...
I would think that the reason that the cars with more hp (600+ was mentioned) wouldn't have this issue would be the simple fact that you have too much power and not enough tire... depending on what hp voodoo is running and if he is in fact rolling on 315's in the rear that would explain it.. just enough power and LOTS of traction could cause this (IMHO).
2006 CTS-V
I don't think he's widened his stockers yet so he's not running 315s (could be wrong of course)
Voodoo you spray wd-40 on there to make sure the bead sealed? ROFL!!!
EDIT: This GIF was shamelessly stolen from the Tony Show
1 - 14 of 14 Posts
