I just bought a beautiful white diamond '07 Escalade with 305/40/22
tires.
The tire pressure decal on the door indicates 265/65/18's. A big difference.
Pressures indicated are 30# (for the 265's).
What pressures should I run for normal driving for the 305's?
2005 cts-v/ 2003 Escalade EXT
I have 22's on my Escalade and i run 35 pounds per the local tire shops advice....so thats what i would suggest.
2012 Escalade, 2014 SRX
I run 35-36 lbs in my 18's and 22's , 40 lbs in my 24's and 26's
Premium Member
17 XTS Platinum V-Sport; 17 Buick Envision AWD Turbo; 10 Lincoln MKS AWD Twin Turbo
Wow, maybe I need to up my 18" pressure. I use the door recommended 30 PSI COLD. They usually heat up to 33-35 depending on temp outside. I used to fill more than recommended in my Tahoes, but then had cupped tires once which the tire shop said was likely caused by overinflation....
I get decent gas mileage and the tires seems to be wearing well. I would prefer a bit more pressure though. Thoughts?
