2013 EXT
Planning to buy an extra set of wheels/tires for for off roading my EXT. Looking at pressure sensors and found prices from $40 for a set of four to over $60 each. Anyone used the cheap ones? Pros and cons?
Go ahead, blame me. Everybody does 馃檮
Re: Tire pressure sensor
A few things I've taken note of when researching TPMS sensors:
* These are inconvenient to replace when they stop functioning. You get what you pay for.
* They are battery powered; batteries have a shelf life. The average lifespan of TPMS sensors are approximately 7 yrs. Some live longer, some shorter. If you're buying used sensors, you're already cutting into that lifespan.
* Some of the cheaper sets on eBay are "new" sensors, but are either cheap-quality knockoffs or leftovers that have been sitting on a shelf somewhere for who knows how long. Again, you're cutting into the sensor lifespan. If the seller can't/won't tell you when they were manufactured, they're most likely old and/or cheap quality.
If you're just purchasing an additional set of tires/wheels for off road use, I say skip the TPMS and ignore the orange triangle on the dash. Your original tire/wheel TPMS will sync back up to the truck when you swap them back.
2013 EXT
Thanks. Probably best to do without as lowering air pressure when going off road will be giving me a low pressure alert.
