Long time reader, first time writer. I was reading these forums before I ever bought a caddy. I finally bought a 1970 Coupe.
I am a novice, mechanically, and will probably have a few people cringing when they hear how I caused my current dillema:
My car was hesitating and running awful 2 nights ago. It stalled. I usually only stall when I'm leaning out. (I have run the thing out of gas). I got it to the station, put gas in and it was still running like crap. So I figured it was a timing issue. It was doing things similar to what it was doing when the timing was off before.
I replaced the points fairly recently so I didn't think it was the points. In retrospect, it was running EXACTLY the way it ran before I changed the points...so I probably should have tried adjusting the points first.
INSTEAD, under the assumption that it couldn't possibly be the points. I made a theory: The engine was whipped and is more whipped now from driving it for a year. It needed to have the timing advanced to run smoothly before the new points, at 7 and a half BTDC it would overheat and idle very rough, so I figured it was time to advance the timing again. It was already advanced as far as it would physically go. The vacuum advance was in the way, and someone had already bent it as far as it would bend against the AC compressor.
I took the cap and rotor off witht he goal of taking the vacuum advance off so I could manually advance the timing more. The plate that the points sit on right above the vacuum advance base was originally very tight... and I couldn't get the screws off the advance because that plate gives very little clearance.. I forced them out by twisting them sideways under the plate. The plate is now very loose. wherin lies my question(s)
Can the car run like this? Can I just tighten it back up somehow? Do I need to reset the timing? Did I break my distributor? Please, anyone who knows what I'm talking about, I'm in the dark :hmm: and I want to get my Cad running again.
