CTS
2004 CTS 3.2L 5pd Manual. I was wondering if anyone has made a conversion kit from belt to chain. I figured if it has to be torn down I may as well make it the last time it has to be opened up for this. Thanks for any help.
2004 cts
Im not a expert on Cadillac engines by no means but i would think even if there was a kit to do this it would be too expensive to justify what you may gain if anything. Jesse
2012 SRX Performance FWD, Platinum Ice
It's likely possible from an engineering standpoint...not at all worth the cost of the conversion. You'd be better off swapping for a 3.6 and that would be assuming your current motor is toast and it's an easy swap. Otherwise, get a belt change when due and drive on the next 100K miles
