05 STS N* RWD
Hello, just bought an 05 STS N* V-8. It has 86,000 mi and it has a very light tapping noise at idle and on acceleration. Under load, it seems to lessen in between shifts and under heavy acceleration. The sound is like a lifter tap on a push-rod engine. Any thoughts would be appreciated. Thanks
2007 Cadillac STS
If its a tapping noise it could be a hyraulic valve adjuster. Where is the sound coming from exactly? Its hard to diagnose a sound with out actually listening to the vehicle.
2006 STS 1SG & 2007 STS 1SE
There are a lot of quieter engines than the N*. There's probably no real problem. There are a lot of things that can tick.
Use the old hose trick if you can't isolate the location of the noise. Take a length of garden hose (2 feet?) and listen to one end while probing with the other.
2014 XTS V-Sport Platinum
Mine ticks a bit after a cold start, but gets much quieter after it has warmed up. I agree with the fresh Mobil 1 change idea...can't hurt.
2008 STS-V and 2003 Escalade, 2005 STS4 1sg (sold)
Mine has a ticking noise too at idle mostly but when I asked the mechanic he said that most sts's that he works on has the same noise and told me not to worry about it
Cadillac Owners Troll
2019 CT6 Sport 3.0TT,2015 Luxury ATS , 2016 ELR, and Volt
Does your car still have the engine cover on it? Many people assume it's just a beauty cover but the injectors and EGR valve make a lot of ticking noise.
