Have a 90 Deville, 4.5L, with only 75,000 (literally bought it from a little old lady). It has decided to take on the task of accelerating on it's on. I can turn a corner at 18mph, never touch the accelerator, and be going 45mph within 2 blocks. I can cruise between 67-70 mph on the highway without using either cruise control or the gas pedal. Getting scary in town as I have to keep brake engaged to stay close to speed limit.
Been to dealer 5 times. They have changed the fuel sensor, recalibrated the sensor, changed the clips that hold the sensor, rewired everything to the sensor, still no relief.
Any Ideas?.......thanks
WELCOME to the forums :welcome: :welcome:
That is what makes caddy's great that is how i got mine. Well you are having the same problem that i had. It's an easy fix just time consuming. What i did was to take out the throttle body and CLEAN the hell out of it. I scrubbed all of the carbon off of it and then put it back together. Now it runs GREAT. I highly recomend doing it if you are confident in doing so. I will warn you though a lot of the rubber is going to be dry rotted so make sure that the dealer is open and you have another car.
2005 CTS-V, 1994 Infiniti Q45
You can get the TB pretty clean (clean enough so it wont stick) without taking it off if you dont think your up to the task......
