1 - 10 of 10 Posts
'96... what are the specs for the throttle body and throttle body spacer?
My book lists 106 inch-lb for the TB, but doesn't list the spacer to manifold torque?? :confused:
1.21 gigawatts. And if that doesn't work, try 42. :thumbsup:
eldorado1 said:
So, nobody has a manual for a 96-99? Or you just can't find the spacer to manifold specs either??
I moved in June and haven't seen my FSM since... If I can dig it out of the garage somewhere, I'll look it up and let you know today.
Discussion Starter · #10 ·
Hmm... I could understand if they were a different length, but they're not..
Maybe I'll just tighten everything to 89 in-lbs... This wouldn't be the first time I massaged the torque specs to prevent problems - I installed the intake manifold with 75in-lb instead of the recommended 89, due to a problem with the last install cracking the intake.
1 - 10 of 10 Posts
