05 Cadillac dts
Has anyone had an issue with replacing the trunk lid brake light. Mine went out and I purchased a used one and it doesn't work either. Could there be a problem with the connection? How do I find out?
How do I find out?
easiest way would be to use a simple test light -
Check the wiring harness for chafed/broken wiring where it exits the left trunk hinge bracket - inside the pop-off plastic trim cover. Also, the body ground for that harness at the left rear fenderwell stud - under the carpet.
For more info and removal instructions see www.ledfix.com. Logan used to be a vendor here.
