1 - 8 of 8 Posts
2004 Deville
So I'm thinking about putting a hitch on my 2004 Deville to pull a 2,000 lb popup camper. I currently have a RIM C0660 Level Control Exhaust Valve Circuit Malfunction code, so I'm not sure my ride height leveler is working. I also have been noticing hesitation from 1st to 2nd gear on the transmission. Will pulling a camper exacerbate these problems? What else should I be concerned about with doing this?
No, your elc system cannot vent and is disabled. You can get a new OEM compressor from Arnott for just over $200. Pr, you can get a manual fill kit from Monroe, and adjust it with any air compressor as toy would a tire.
As for the hesitation, I'd start by pulling codes and checking fluid level/condition.
you didn't mention how many miles on the car -
or how far you might tow the trailer -
2000lbs is the maximum limit of towing capacity -
towing that amount of weight 50 or 100 miles -
is a completely different story -
than planning a cross-country 2000 mile trip -
it certainly will not help the trans -
and you will have to replace the ELC compressor -
or install the manual-fill kit like MoistCabbage said -
unless the trailer has GREAT disc type brakes -
you might consider upgrading your existing brakes -
to heavy duty pads and rotors -
1992 Fleetwood S&S Hearse, 1993 Buick Roadmaster
If I thought my transmission was acting up, the last thing I'd want to do is haul a bunch of extra weight across the country. Sounds like a recipe for disaster.
98 ETC (RIP), 01 Deville
If you are going to tow anything. I would strongly recommend adding an additional transmission cooler, like a Hayden 403.
1985 Sedan DeVille
TBH I don't think I would put a one-ton camper behind a vehicle with active air suspension. Probably ought to look into some air spring helpers just to keep the ride mostly level, and then pull the fuse on the pump
so many errors in this - where to start -
the Deville does not have air suspension -
it has coil-spring suspension - with ELC -
Electronic Level Control - in the rear -
only the DTS model Deville has "active" struts and shocks -
the base and DHS model Deville have passive struts and shocks -
a properly balanced 2000lb trailer will have around 150 to 200lb tongue weight -
the ELC shocks would have no problem supporting that weight -
2011 CTS Coupe FE3, 2003 Thunderbird, Gone 2013 ATS, 02 Deville
I towed a empty enclosed trailer 6x8 and seven ft tall with my 2002 deville. The car did not like it. I live in Las Vegas we have hills and hot weather, had to shut the A/C off to keep the engine from over heating, and it was still running high heat. The Northstar engine is very small and has no torque, tranny was always shifting to a lower gear. I could not imagine towing 2,000 lbs with the deville. Better get brakes on the trailer and AAA for towing when the car breaks down.
1 - 8 of 8 Posts
