I recently bought a 2006 CTS, after 3 days the theftlock came on along with traction control light once the theftlock comes on, I can't rolled my windows down, the radio powers off and I can't take the key out of the ignition until after several attempts then the I can remove the key. The dealer replaced the ecm and 2 days after getting it out of the shop and spending $3000 the problem begun again. I took it back and they don't have a clue. Its been in the shop for 2 days now. Any suggestions?
I bought a 04 CTS about a year ago. I encountered some of the same issues as you. My car stopped cutting on and the key keeps getting stuck in the ignition. I replaced my ECU and my car ran fine for about 2 months but now the problems came back. Do you think I need to change my ECM as well? I noticed this problem occurred for you in 2013 maybe you can help now. Any information would be helpful.
08 STS 1SG HUD ACC F55 AWD, 08 STS 1SG Platinum HUD ACC F55 RWD
The OP is probably not going to answer. I think it was his only post. The fact that you replaced the ECU which temporarily fixed problem makes me think corrosion in the connectors. Clean/inspect and use D5 and dielectric grease. See if that helps first. Good Luck
