1 - 8 of 8 Posts
· Administrator
I did have a lock smith bypass the system with resisters. The car worked just fine for a long time but now its saying the theft problem. She will not start. What can I do?
Welcome to CF !!!
What car, make, model, year ??? Please update your profile so the name/login banner looks sort of like those of other members.
Probably need to test the resistor circuit to verify one is not fried.
My first pass at bypass ended up loosening up and had to redo them.
Also, mine are at the low end of the acceptable range and when it is really cold and damp, it falls below acceptable range throwing the same security symptom
2001 Eldorado 2008 DTS 2005 XLR 95 Eldo'11CTS-V,'66 corvair.'03 deville,'00 deville
The resistance of the resistor needs to be within 5% of the actual key pellet.
Standard resistors don't follow what the General gave to the pellet resistors, so you have to manually measure standard resistors in the range you need to be within the 5%
All resistors have a tolerance range, usually 10%, but could be 1,5,10, or 20% depending on the last (4th) color band on the resistor.
Gold= 5%
silver=10 %
No forth band=20%
· Administrator
Mix & Match to get to the correct resistance -
Two resistors in parallel lowers total resistance. Two resistors in series raises total resistance.
1 - 8 of 8 Posts
